[gdal-dev] python code inside of VRT results to empty values
Jachym Cepicky
jachym.cepicky at gmail.com
Mon May 25 01:44:10 PDT 2020
Hi all,
I have some python code inside of VRT file, but I can not produce
reasonable output with gdal_transalte. All the input data do look ok,
even when I print() the values I would like to store, the data are
displayed, but the resulting TIFF file is just empty, any hint how to
approach? I've tested it on gdal 2.2 as well as 3.8, so I assume, I do
something wrong here. The minimal code looks like
import numpy as np
import copy
def blur(in_ar, out_ar, xoff, yoff, xsize, ysize, raster_xsize,
raster_ysize, buf_radius, gt, **kwargs):
out_ar = copy.copy(in_ar[0])
print(out_ar)
return out_ar
Any hint?
Thank you
Jachym
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
