[gdal-dev] Passing open options along dataset name in a string ?
Even Rouault
even.rouault at spatialys.com
Mon Nov 2 02:10:11 PST 2020
I've heard interest in having the capability of passing a GDAL dataset name
and its open options in a single string, since this is easier for storing.
The syntax could be a JSON serialized string prefixed by GDAL_JSON: to avoid
any ambiguity with drivers that would accept JSON as a connection string/
dataset name.
So something like:
GDAL_JSON:{"dataset":"foo.csv","open_options":["AUTODETECT_TYPE=YES",
"KEEP_GEOM_COLUMNS=NO"]}
A "allowed_drivers" member could also be added to reflect the corresponding
argument of GDALOpenEx()
GDALOpen()/GDALOpenEx() would parse this, and process that exactly as if it
was called with the dataset name, open options and allowed drivers put in the
dedicated C arguments. So no change in drivers, just in GDALOpenEx().
If using that syntax, it wouldn't make sense to have both serialized options
and options passed as C-argument together, so a warning would be emitted if
that happened
Thoughts ?
Even
http://www.spatialys.com
