[gdal-dev] Passing open options along dataset name in a string ?
Sean Gillies
sean at mapbox.com
Wed Nov 4 06:43:52 PST 2020
Even,
On Wed, Nov 4, 2020 at 3:40 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Sean,
> What GDN stands for: GDAL Dataset Name ?
Yes. I just made that up on the spot. Think of it as a GDAL or FOSS4G
specific namespace. Until now, GDAL has been using symbols like WFS: and
HDF5: in the global namespace, which causes problems for interoperability.
> > The URN or GDN version might look something like the thing below, using
> > and ?= [3] to identify vsi and driver option sections
> > gdn:curl:csv:
> example.com/foo.csv?a=1&b=2?+max_retry=5?=autodetect_type=yes&keep_geom_colu
> > mns=no
> The http or https protocol should be captured too.
> > Bringing a little more order to how we name and address datasets was on
> my
> > todo list at the start of the year, but then 2020 went into a spiral. I
> > don't think rasterio's "zip+s3" etc approach is the best.
> I see fsspec has a syntax for chaining filesystems in
> https://filesystem-spec.readthedocs.io/en/latest/features.html#url-chaining
Yes, I recognized this as being a different approach to a similar problem
we have in GDAL: data files that can be accessed with different layers of
optional protocols.
> Another particularity we have in GDAL is that the dataset name might be
> almost
> anything. Most of the time, it is a regular file path, or some /vsi path.
> But
> sometimes, it can be JSON content (the GeoJSON driver accepts the content
> to
> be directly provided as the dataset name), or XML (VRT, WMS drivers).
> We have also the subdataset syntax "HDF5:foo.hdf:my_variable"
Could VRT XML and JSON be exempted? We already have a way to embed open
options in the XML.
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201104/25f26c19/attachment-0001.html>
