[gdal-dev] Reading a VRT file & overview usage
Even Rouault even.rouault at spatialys.com
Wed Nov 4 07:04:37 PST 2020
Angus,
The difference of behaviour between my test case and yours is that yours has a
<NoDataValue> set on the VRTRasterBand, and the source COGs don't have that
value. In this situation a key optimization used by the VRT driver is
disabled, and there's a fallback to code that won't make use of the source
overviews to get correct results. I imagine that could be improved, but this
is not a 5-minute type of fix. A workaround would probably to create your COGs
with 0 set as nodata value.
Even
http://www.spatialys.com
