[gdal-dev] Spherical Mercator Projection mismatching major/minor axis
Even Rouault
even.rouault at spatialys.com
Fri Nov 6 11:24:22 PST 2020
Craig,
> The way I handle it is (slightly older notation):
> PROJCS["WGS84 / Spherical Mercator",
> GEOGCS["WGS84basedSpheric_GCS",
> DATUM["WGS84basedSpheric_Datum",
> SPHEROID["WGS84based_Sphere", 6378137, 0]],
> PRIMEM["Greenwich", 0],
> UNIT["degree", 0.0174532925199433]],
> PROJECTION["Mercator"],
> PARAMETER["latitude_of_origin", 0],
> PARAMETER["central_meridian", 0],
> PARAMETER["false_easting", 0],
> PARAMETER["false_northing", 0],
> UNIT["meter", 1],
> AUTHORITY["EPSG", "3857"]]
The above WKT using plain Mercator and a sphere definition could potentially
result in incorrect datum transformation being done by some systems if
transforming coordinates from a non-WGS84 based CRS to this definition
(actually just testing it with PROJ >= 6 or GDAL <= 2.4, it rejects its
because it doesn't know the 'Mercator' projection method. Should be
'Mercator_1SP' for the WKT1 dialect that GDAL/PROJ speaks)
Jukka was quite correct: EPSG:3857 is defined on the WGS 84 datum, but the
projection method to use is spherical mercator, that is forcing flattening to
0. See https://epsg.org/crs/wkt/id/3857
> Will GDAL accept a "0" for the inverse of flattening to represent a sphere?
Yes. That's the canonical way of expressing a sphere
Even
http://www.spatialys.com
