[gdal-dev] WCS_GDAL Driver Image SubSet Request
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Mon Nov 9 07:47:05 PST 2020
Do you want to make is somehow impossible to request data beyound the
BoundingBox that you defined in the XML file? If you just want to get data
from the rectangle that you or your users define, gdal_translate with the
regular -spat option should work out-of-the-box.
-Jukka Rahkonen-
juliermeopensourcedeveloper wrote
> Hi all,
> Is it possible to define a bounding box in order to request a coverage
> subset using the GDAL WCS Driver?
> I have tried the code in [1]. I am trying to get information only for the
> bbox_interest=( -58,-11,-57.75,-10.75) as shown below, however the subset
> image or bbox_interest request has not been delivered. The West Longitude
> reaches -50.17 and The Lower Latitude reaches -18.92 which are limits out
> of the bbox_interest.
> The image extent is:
> <GetCoverageExtra>
> &BoundingBox=-63.280290728152664,-13.794296142085976,-53.624004749255874,-5.636644661059637
> </GetCoverageExtra>
> Any comment on this issue will be greatly appreciated.
> Thank you very much for your time in advance.
> *CODE [1]:*
> <WCS_GDAL>
> <ServiceURL>
> http://172.21.14.45:6060/geoserver/wcs?version=1.0.0&
> ServiceURL>
> <CoverageName>
> cbers_deter_amazonia:CBERS-4_AWFI_170_111_21052020
> CoverageName>
> <GetCoverageExtra>
> &BoundingBox=-58,-11,-57.75,-10.75
> </GetCoverageExtra>
> <CoverageOffering>
> <description>
> Generated from GeoTIFF
> </description>
> <name>
> </name>
> <label>
> </label>
> <lonLatEnvelope srsName="urn:ogc:def:crs:OGC:1.3:CRS84">
> <pos>
> -58 -11
> </pos>
> <pos>
> -57.75 -10.75
> </pos>
> </lonLatEnvelope>
> <keywords>
> <keyword>
> WCS
> </keyword>
> <keyword>
> GeoTIFF
> </keyword>
> </keywords>
> <domainSet>
> <spatialDomain>
> <Envelope srsName="EPSG:4326">
> <pos>
> -58 -11
> </pos>
> <pos>
> -57.75 -10.75
> </pos>
> </Envelope>
> <RectifiedGrid dimension="2" srsName="EPSG:4326">
> <limits>
> <GridEnvelope>
> <low>
> 0 0
> </low>
> <high>
> 0 0
> </high>
> </GridEnvelope>
> </limits>
> <axisName>
> x
> </axisName>
> <axisName>
> y
> </axisName>
> <origin>
> <pos>
> -58 -10.75
> </pos>
> </origin>
> <offsetVector>
> 0.005364603321609328 0.0
> </offsetVector>
> <offsetVector>
> 0.0 -0.004532028600570188
> </offsetVector>
> </RectifiedGrid>
> </spatialDomain>
> </domainSet>
> <rangeSet>
> <RangeSet>
> <name>
> </name>
> <label>
> </label>
> <axisDescription>
> <AxisDescription>
> <name>
> Band
> </name>
> <label>
> Band
> </label>
> <values>
> <interval>
> <min>
> 1
> </min>
> <max>
> 4
> </max>
> </interval>
> </values>
> </AxisDescription>
> </axisDescription>
> </RangeSet>
> </rangeSet>
> <supportedCRSs>
> <requestResponseCRSs>
> EPSG:4326
> </requestResponseCRSs>
> </supportedCRSs>
> <supportedFormats nativeFormat="GeoTIFF">
> <formats>
> GeoTIFF
> </formats>
> <formats>
> GIF
> </formats>
> <formats>
> JPEG
> </formats>
> <formats>
> PNG
> </formats>
> <formats>
> TIFF
> </formats>
> </supportedFormats>
> <supportedInterpolations default="nearest neighbor">
> <interpolationMethod>
> nearest neighbor
> </interpolationMethod>
> bilinear
> bicubic
> </supportedInterpolations>
> </CoverageOffering>
> <PreferredFormat>
> GeoTIFF
> </PreferredFormat>
> <BandCount>
> 4
> </BandCount>
> <BandType>
> Byte
> </BandType>
> </WCS_GDAL>
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
