[gdal-dev] GDAL 3.1.2: PROJ_DEBUG
Daniel Mellergård daniel.mellergardh at gmail.com
Tue Nov 17 06:01:07 PST 2020
Is setting the environment variable PROJ_DEBUG=3 supposed to work when
using GDAL3.1.2? Running for example gdalsrsinfo with that environment
variable set has no effect, but running projinfo (from proj 6.3.2) does.
I assume this has something to do with different "contexts" in Proj?
Also, by programmatically using proj_log_level, I can see that the log
level has been picked up by Proj in the default context.
BR,
Daniel
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201117/ae25aee3/attachment.html>
