[gdal-dev] Geometry column name: Field 'OGR_GEOMETRY' not found in source layer
Even Rouault even.rouault at spatialys.com
Thu Nov 19 16:02:06 PST 2020
On jeudi 19 novembre 2020 23:42:59 CET Jorge Gustavo Rocha wrote:
> Hi,
> Only now, based on Even's answer, I was able to find the proper
> documentation. My fault! I was searching using uppercase and git grep
> "_OGR_GEOMETRY_" was returning nothing.
> Just an update regarding the documentation:
> 1) OGR_GEOMETRY is well documented at
> https://gdal.org/user/ogr_sql_dialect.html#ogr-geometry
> 2) "_OGR_GEOMETRY_" is also pretty well documented in the same document,
> at https://gdal.org/user/ogr_sql_dialect.html#geometry-field
Jukka added that one just a few days ago
> 3) As an alternative for all drivers, GEOMETRY field, used in SQL SQLite
> dialect, is well documented at
> https://gdal.org/user/sql_sqlite_dialect.html#geometry-field
I've added in
https://gdal.org/programs/ogrinfo.html#cmdoption-ogrinfo-dialect
an hyperlink to the 2 above pages. Similarly for ogr2ogr
http://www.spatialys.com
