[gdal-dev] gdal-dev Digest, Vol 198, Issue 14
1520 gis juliermeopensourcedeveloper at gmail.com
Fri Nov 20 05:54:00 PST 2020
Dear all,
I would like to open this discussion here about creating a xml/ raster wcs
ingest using gdal_translate.
My 2 goals are:
1 - get a xml like in [1] by running command line similar do gdal_wmts
driver in [2]
gdal_translate "WCS:
http://demo.geo-solutions.it:80/geoserver/wcs?version=2.0.1&coverage=nurc__Img_Sample
" wcs.xml -of WCS
*OR*
http://demo.geo-solutions.it/geoserver/ows?service=WCS&request=getCapabilities,layer=nurc__Img_Sample
" wcs.xml -of WCS
2 - get a xml / raster subset
" wcs.xml -projwin -100 40 -80 30 -of WCS
*OR*
If the solution I am trying to get can not be possible through
gdal_translate, would someone have a xml sample  like [1], but with raster
subset ingest, instead the whole image content.
I appreciated your time in advance.
Kind regards
Julierme
[1] <WCS_GDAL>
  <ServiceURL>https://demo.geo-solutions.it/geoserver/wcs?version=2.0.1&amp
;</ServiceURL>
  <CoverageName>nurc:Img_Sample</CoverageName>
<GetCoverageExtra>&BoundingBox=-130.85168,20.7052,-62.0054,54.1141</GetCoverageExtra>
</WCS_GDAL>
[2] gdal_translate "WMTS:
http://maps.wien.gv.at/wmts/1.0.0/WMTSCapabilities.xml,layer=lb" wmts.xml -
of WMTS.
On Tue, Nov 10, 2020 at 6:18 PM Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> Sorry for the -spat that belongs to ogr2ogr. In gdal_translate it is
> -projwin.
> The WMTS documentation is not relevant for the GDAL WCS driver. Most that
> they have in common is that they create a xml file for storing info about
> the capabilities of the service.  The WCS documentation alone should be
> enough for using the WCS driver, even I have to admit that I do not
> understand it totally, for example when it comes to cache control commands.
> Fortunately documentation can be improved.
> Using WCS with GDAL is meant to be easy but unfortunately it seems to me
> that something is broken with it with some WCS services. It should be this
> easy to use:
>    1. Read general capabilities, including the names of the coverages.
>    Example
> gdalinfo "WCS:http://demo.geo-solutions.it/geoserver/wcs?version=2.0.1"
> The result contain the names of the subdatasets (coverages) as the WCS
> driver understands them
> Subdatasets:
>   SUBDATASET_1_NAME=WCS:
> http://demo.geo-solutions.it:80/geoserver/wcs?version=2.0.1&coverage=nurc__Arc_Sample
>   SUBDATASET_2_NAME=WCS:
> http://demo.geo-solutions.it:80/geoserver/wcs?version=2.0.1&coverage=sde__GRAY_HR_SR_OB_DR
>   SUBDATASET_3_NAME=WCS:
> http://demo.geo-solutions.it:80/geoserver/wcs?version=2.0.1&coverage=sde__HYP_HR_SR_OB_DR
>   SUBDATASET_4_NAME=WCS:
> http://demo.geo-solutions.it:80/geoserver/wcs?version=2.0.1&coverage=sde__NE2_HR_LC_SR_W_DR
>   SUBDATASET_5_NAME=WCS:
>   SUBDATASET_6_NAME=WCS:
> http://demo.geo-solutions.it:80/geoserver/wcs?version=2.0.1&coverage=geosolutions__black_marble
>   SUBDATASET_7_NAME=WCS:
> http://demo.geo-solutions.it:80/geoserver/wcs?version=2.0.1&coverage=geosolutions__g30
>   SUBDATASET_8_NAME=WCS:
> http://demo.geo-solutions.it:80/geoserver/wcs?version=2.0.1&coverage=nurc__mosaic
>   SUBDATASET_9_NAME=WCS:
> http://demo.geo-solutions.it:80/geoserver/wcs?version=2.0.1&coverage=sf__sfdem
>   SUBDATASET_10_NAME=WCS:
> http://demo.geo-solutions.it:80/geoserver/wcs?version=2.0.1&coverage=geosolutions__truemarble
>    1. Select one coverage and read more metadata about that, again with
>    gdalinfo. This step fails now with my GDAL 3.2. Here some debug info that
>    shows that GDAL is generating a bbox/subset with lower limit = higher limit
>    when it tries to read a small sample of the coverage. Geoserver does not
>    accept the request and gives an error about an empty subset.
> gdalinfo "WCS:
> http://demo.geo-solutions.it/geoserver/wcs?version=2.0.1&coverage=nurc__mosaic"
> --debug on
> WCS: Requesting
> http://demo.geo-solutions.it/geoserver/wcs?SERVICE=WCS&REQUEST=DescribeCoverage&VERSION=2.0.1&COVERAGEID=nurc__mosaic&FORMAT=text/xml
> HTTP: Fetch(
> HTTP: libcurl/7.70.0-DEV OpenSSL/1.1.1g zlib/1.2.3
> WCS: Requesting
> http://demo.geo-solutions.it/geoserver/wcs?SERVICE=WCS&REQUEST=GetCoverage&VERSION=2.0.1&COVERAGEID=nurc__mosaic&SUBSET=Long%286.3953399152693953,6.3953399152693953%29&SUBSET=Lat%2846.541601968340089,46.541601968340089%29&Format=image/tiff
> HTTP: Fetch(
> ERROR 1: HTTP error code : 404
> ERROR 1: InvalidSubsetting: Empty intersection after subsetting
>    1. The third step would be to use gdal_translate with -projwin option
>    and get coverage from the given area. Now gdal_translate is also making a
>    probing request by min=max extents and it fails.
> However, the example request on the WCS document page that reads data from
> the National Land Survey of Finland  works.
> gdal_translate -oo CACHE=wcs_cache -oo CLEAR_CACHE -oo INTERLEAVE=PIXEL
> -projwin 377418 6683393.87938218 377717.879386966 6683094 -oo
> Subset="time(1985-01-01T00:00:00.000Z)" -outsize 60 0 "WCS:
> https://beta-karttakuva.maanmittauslaitos.fi/wcs/service/ows?version=2.0.1&coverage=ortokuva__ortokuva"
> scaled.tiff
> gdalinfo works as well
> gdalinfo "WCS:
> -Jukka Rahkonen-
> *Lähettäjä:* 1520 gis <juliermeopensourcedeveloper at gmail.com>
> *Lähetetty:* tiistai 10. marraskuuta 2020 18.10
> *Vastaanottaja:* gdal-dev at lists.osgeo.org; Rahkonen Jukka (MML) <
> *Aihe:* Re: gdal-dev Digest, Vol 198, Issue 14
> Dear Jukka Rahkonen,
> Thank you very much for your reply.
> First of all, my apologies for my lack of knowledge about using GDAL_WCS
> driver. Let me give more details about the issues I am facing.
> Extract of
> http://172.21.14.45:8181/geoserver/ows/wcs?request=GetCapabilities is
> shown in [1].
> Regarding gdal_translate GDAL_WCS driver Image subset extract, looking at
> https://gdal.org/drivers/raster/wcs.html#examples, I tried the following:
> Similar to GDAL_WMTS <gdal_translate "WMTS:
> http://maps.wien.gv.at/wmts/1.0.0/WMTSCapabilities.xml,layer=lb" wmts*.*
> xml *-*of WMTS>,
> I tried running:
> (1)
> http://172.21.14.45:8181/geoserver/wcs?version=2.0.1&coverage=deter-amazonia__CBERS-4_AWFI_170_111_21052020"
> CBERS-4_AWFI_170_111_21052020.xml
> *The response:* I did not get the xml as wmts.xml showed above
> Note: Including the -of option (WCS), the outcome fails
> (2)
> http://172.21.14.45:8181/geoserver/ows/wcs?request=GetCapabilities&coverage=deter-amazonia__CBERS-4_AWFI_170_111_21052020"
> -spat -58 -11 -57.75 -10.7 \
> *The response:* There is no -spat option for gdal_translate
> *gdal_translate --help*
> Usage: gdal_translate [--help-general] [--long-usage]
>        [-ot {Byte/Int16/UInt16/UInt32/Int32/Float32/Float64/
>              CInt16/CInt32/CFloat32/CFloat64}] [-strict]
>        [-of format] [-b band] [-mask band] [-expand {gray|rgb|rgba}]
>        [-outsize xsize[%]|0 ysize[%]|0] [-tr xres yres]
>        [-r {nearest,bilinear,cubic,cubicspline,lanczos,average,mode}]
>        [-unscale] [-scale[_bn] [src_min src_max [dst_min dst_max]]]*
> [-exponent[_bn] exp_val]*
>        [-srcwin xoff yoff xsize ysize] [-epo] [-eco]
>        [-projwin ulx uly lrx lry] [-projwin_srs srs_def]
>        [-a_srs srs_def] [-a_ullr ulx uly lrx lry] [-a_nodata value]
>        [-a_scale value] [-a_offset value]
>        [-nogcp] [-gcp pixel line easting northing [elevation]]*
>        |-colorinterp{_bn} {red|green|blue|alpha|gray|undefined}]
>        |-colorinterp {red|green|blue|alpha|gray|undefined},...]
>        [-mo "META-TAG=VALUE"]* [-q] [-sds]
>        [-co "NAME=VALUE"]* [-stats] [-norat]
>        [-oo NAME=VALUE]*
>        src_dataset dst_dataset
> [1] WCS GetCapabilities request
> <wcs:CoverageSummary>
> <ows:Title>CBERS-4_AWFI_170_111_21052020</ows:Title>
> <ows:Abstract>Generated from GeoTIFF</ows:Abstract>
> <ows:Keywords>
> <ows:Keyword>deter-amazonia-CBERS-4_AWFI_170_111_21052020</ows:Keyword>
> <ows:Keyword>WCS</ows:Keyword>
> <ows:Keyword>GeoTIFF</ows:Keyword>
> </ows:Keywords>
> <wcs:CoverageId>deter-amazonia__CBERS-4_AWFI_170_111_21052020
> </wcs:CoverageId>
> <wcs:CoverageSubtype>RectifiedGridCoverage</wcs:CoverageSubtype>
> <ows:WGS84BoundingBox>
> <ows:LowerCorner>-63.280290728152664 -13.794296142085976</ows:LowerCorner>
> <ows:UpperCorner>-53.624004749255874 -5.636644661059637</ows:UpperCorner>
> </ows:WGS84BoundingBox>
> <ows:BoundingBox crs="http://www.opengis.net/def/crs/EPSG/0/EPSG:4326">
> </ows:BoundingBox>
> </wcs:CoverageSummary>
> Any comment will be very appreciated.
> GDAL website <https://gdal.org/drivers/raster/wmts.html> provides
> examples on how to run GDAL_WMTS driver in order to get a wmts xml file. I
> have looked in https://gdal.org/drivers/raster/wcs.html and could not
> find an example pointing to -spat option.  I got an -spat option
> to gdal_grid
> <https://gdal.org/programs/gdal_grid.html?highlight=spat#cmdoption-gdal_grid-spat>
> though.
> gdal_translate "WMTS:http://maps.wien.gv.at/wmts/1.0.0/WMTSCapabilities.xml,layer=lb" wmts*.*xml *-*of WMTS
> gdal_translate "WCS:http://www.dpi.inpe.br/fipcerrado-geoserver/ows/wcs?request=GetCapabilities" \
> -oo CoverageName=deter-cerrado:CBERS-4_AWFI_161_099_13072018 CBERS-4_AWFI_161_099_13072018.xml -of WCS
> On Mon, Nov 9, 2020 at 5:00 PM <gdal-dev-request at lists.osgeo.org> wrote:
> Send gdal-dev mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.osgeo.org/mailman/listinfo/gdal-dev
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         gdal-dev-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of gdal-dev digest..."
> Today's Topics:
>    1. Re: Selecting just the geometry column with OGR SQL (Even Rouault)
>    2. Re: Selecting just the geometry column with OGR SQL
>       (Rahkonen Jukka (MML))
>    3. Re: WCS_GDAL Driver Image SubSet Request (jratike80)
> Message: 1
> Date: Mon, 09 Nov 2020 16:09:45 +0100
> From: Even Rouault <even.rouault at spatialys.com>
> To: gdal-dev at lists.osgeo.org
> Cc: "Rahkonen Jukka (MML)" <jukka.rahkonen at maanmittauslaitos.fi>
> Subject: Re: [gdal-dev] Selecting just the geometry column with OGR
>         SQL
> Message-ID: <1659214.2tRo4lr4Oo at even-i700>
> Content-Type: text/plain; charset="us-ascii"
> Jukka,
> > I believe that OGR SQL dialect adds the geometry column into SQL
> selection
> > by default. Am I right with this? I volunteer to edit the documentation
> > https://gdal.org/user/ogr_sql_dialect.html if this is the case. But
> what I
> > can't understand is another side of the story, how to select just the
> > geometry field with OGR SQL dialect from some data sources.
> > This command returns both time column and geometry from GML
> > ogrinfo -sql "select time from timetest" timetest.gml
> > I can select just the geometry from geometry column named as
> > "geometryProperty" by ogrinfo -sql "select geometryProperty from
> timetest"
> > timetest.gml
> > The behavior is the same with SpatiaLite when I use "-dialect OGRSQL".
> > Geometry is selected automatically but it can be selected also by name.
> But
> > I cannot discover any way to select just the geometry field from
> shapefile.
> > Is it because geometry column in shapefile does not have any name as this
> > Python test seems to prove?
> > >>> from osgeo import ogr
> > >>> shp_ds = ogr.Open('timetest.shp')
> > >>> shp_lyr = shp_ds.GetLayer(0)
> > >>> shp_lyr.GetGeometryColumn()
> > OpenJUMP JML driver does not report a name for geometry column either.
> Is it
> > rather an exception that drivers give names for the geometry columns? I
> > know I can select only the geometry column with the SQLite dialect, but I
> > am curious.
> Indeed, in OGR SQL, if the geometry column has a non-empty name (typically
> for
> database drivers), you can use it to select it. When the geometry column
> name
> is empty, such as in the shapefile or OpenJUMP driver, you can use
> _ogr_geometry_ (with leading and trainling underscore) to select it. This
> is
> likely undocumented.
> As far as I can see, this was introduced per
> https://github.com/OSGeo/gdal/commit/1519dcb00bd7802d2f701114f0e1cb9b524a547f
> to fix an issue with comparison with empty string literals (this was
> before
> OGR enforced the difference between single-quoted string literals and
> double-
> quoted identifiers)
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> Message: 2
> Date: Mon, 9 Nov 2020 15:35:11 +0000
> From: "Rahkonen Jukka (MML)" <jukka.rahkonen at maanmittauslaitos.fi>
> To: Even Rouault <even.rouault at spatialys.com>,
>         "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
>         SQL
> Message-ID: <d59795ddfd994dee9f5eca836361324a at maanmittauslaitos.fi>
> Even Rouault wrote:
> maanantai 9. marraskuuta 2020 17.10
> > Jukka,
> >> selection by default. Am I right with this? I volunteer to edit the
> >> documentation https://gdal.org/user/ogr_sql_dialect.html if this is
> >> the case. But what I can't understand is another side of the story,
> >> how to select just the geometry field with OGR SQL dialect from some
> data sources.
> >> This command returns both time column and geometry from GML ogrinfo
> >> -sql "select time from timetest" timetest.gml I can select just the
> >> geometry from geometry column named as "geometryProperty" by ogrinfo
> >> -sql "select geometryProperty from timetest"
> >> timetest.gml
> >> name. But I cannot discover any way to select just the geometry field
> from shapefile.
> >> this Python test seems to prove?
> >> Is it rather an exception that drivers give names for the geometry
> >> columns? I know I can select only the geometry column with the SQLite
> >> dialect, but I am curious.
> > Indeed, in OGR SQL, if the geometry column has a nonempty name
> (typically for
> name
> This is likely undocumented.
> before OGR enforced the
> >  difference between single-quoted string literals and double- quoted
> identifiers)
> I could not manage to guess the right syntax for Windows right ahead but
> solved the quiz easily
> with your double-quote hint
> First trial:
> ogrinfo -sql "select _ogr_geometry_ from timetest" timetest.shp
> INFO: Open of `timetest.shp'
>       using driver `ESRI Shapefile' successful.
> ERROR 1: SQL Expression Parsing Error: syntax error, unexpected
> $undefined. Occurred around :
> Second trial:
> ogrinfo -sql "select \"_ogr_geometry_\" from timetest" timetest.shp
> -Jukka-
> > Even
> Spatialys - Geospatial professional services http://www.spatialys.com
> Message: 3
> Date: Mon, 9 Nov 2020 08:47:05 -0700 (MST)
> From: jratike80 <jukka.rahkonen at maanmittauslaitos.fi>
> Subject: Re: [gdal-dev] WCS_GDAL Driver Image SubSet Request
> Message-ID: <1604936825138-0.post at n6.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> Hi,
> Do you want to make is somehow impossible to request data beyound the
> BoundingBox that you defined in the XML file? If you just want to get data
> from the rectangle that you or your users define, gdal_translate with the
> regular -spat option should work out-of-the-box.
> -Jukka Rahkonen-
> juliermeopensourcedeveloper wrote
> > Hi all,
> > Is it possible to define a bounding box in order to request a coverage
> > subset using the GDAL WCS Driver?
> > I have tried the code in [1]. I  am trying to get information only for
> the
> > bbox_interest=( -58,-11,-57.75,-10.75) as shown below, however the subset
> > image or bbox_interest request has not been delivered. The West Longitude
> > reaches -50.17 and The Lower Latitude reaches -18.92 which are limits out
> > of the bbox_interest.
> > The image extent is:
> > <GetCoverageExtra>
> &BoundingBox=-63.280290728152664,-13.794296142085976,-53.624004749255874,-5.636644661059637
> > </GetCoverageExtra>
> >  Any comment on this issue will be greatly appreciated.
> > Thank you very much for your time in advance.
> > *CODE [1]:*
> > <WCS_GDAL>
> > <ServiceURL>
> > http://172.21.14.45:6060/geoserver/wcs?version=1.0.0&
> > ServiceURL>
> > <CoverageName>
> > cbers_deter_amazonia:CBERS-4_AWFI_170_111_21052020
> > CoverageName>
> > <GetCoverageExtra>
> > &BoundingBox=-58,-11,-57.75,-10.75
> > </GetCoverageExtra>
> > <CoverageOffering>
> > <description>
> > </description>
> > <name>
> > </name>
> > <label>
> > </label>
> > <lonLatEnvelope srsName="urn:ogc:def:crs:OGC:1.3:CRS84">
> > <pos>
> > -58 -11
> > </pos>
> > <pos>
> > -57.75 -10.75
> > </pos>
> > </lonLatEnvelope>
> > <keywords>
> > <keyword>
> > WCS
> > </keyword>
> > <keyword>
> > GeoTIFF
> > </keyword>
> > </keywords>
> > <domainSet>
> > <spatialDomain>
> > <Envelope srsName="EPSG:4326">
> > <pos>
> > -58 -11
> > </pos>
> > <pos>
> > -57.75 -10.75
> > </pos>
> > </Envelope>
> > <RectifiedGrid dimension="2" srsName="EPSG:4326">
> > <limits>
> > <GridEnvelope>
> > <low>
> > 0 0
> > </low>
> > <high>
> > 0 0
> > </high>
> > </GridEnvelope>
> > </limits>
> > <axisName>
> > x
> > </axisName>
> > <axisName>
> > y
> > </axisName>
> > <origin>
> > <pos>
> > -58 -10.75
> > </pos>
> > </origin>
> > <offsetVector>
> > 0.005364603321609328 0.0
> > </offsetVector>
> > <offsetVector>
> > 0.0 -0.004532028600570188
> > </offsetVector>
> > </RectifiedGrid>
> > </spatialDomain>
> > </domainSet>
> > <rangeSet>
> > <RangeSet>
> > <name>
> > </name>
> > <label>
> > </label>
> > <axisDescription>
> > <AxisDescription>
> > <name>
> > Band
> > </name>
> > <label>
> > Band
> > </label>
> > <values>
> > <interval>
> > <min>
> > 1
> > </min>
> > <max>
> > 4
> > </max>
> > </interval>
> > </values>
> > </AxisDescription>
> > </axisDescription>
> > </RangeSet>
> > </rangeSet>
> > <supportedCRSs>
> > <requestResponseCRSs>
> > EPSG:4326
> > </requestResponseCRSs>
> > </supportedCRSs>
> > <supportedFormats nativeFormat="GeoTIFF">
> > <formats>
> > GeoTIFF
> > </formats>
> > <formats>
> > GIF
> > </formats>
> > <formats>
> > JPEG
> > </formats>
> > <formats>
> > PNG
> > </formats>
> > <formats>
> > TIFF
> > </formats>
> > </supportedFormats>
> > <supportedInterpolations default="nearest neighbor">
> > <interpolationMethod>
> > nearest neighbor
> > </interpolationMethod>
> > bilinear
> > bicubic
> > </supportedInterpolations>
> > </CoverageOffering>
> > <PreferredFormat>
> > GeoTIFF
> > </PreferredFormat>
> > <BandCount>
> > 4
> > </BandCount>
> > <BandType>
> > Byte
> > </BandType>
> > </WCS_GDAL>
> > gdal-dev at .osgeo
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> Subject: Digest Footer
> End of gdal-dev Digest, Vol 198, Issue 14
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201120/193e6990/attachment-0001.html>
