[gdal-dev] gdal-dev Digest, Vol 198, Issue 45
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Mon Nov 23 07:08:24 PST 2020
I do not know how QGIS deals with this, but how about using VRT? It is XML and you can use it with GDAL tools. Try
Step 1.
gdal_translate -of vrt WCS:"http://demo.geo-solutions.it:80/geoserver/wcs?version=2.0.1&coverage=sf__sfdem" wcs.vrt
Step 2.
gdal_translate -of GTiff -outsize 200 200 -projwin 589980.000 4928010.000 590980.000 4918010.000 wcs.vrt converted_from_wcs_vrt.tif
This VRT file did not work with my QGIS but a VRT created for my local Geoserver works. Steps to follow
gdal_translate -of VRT WCS:"localhost:8080/geoserver/wcs?version=2.0.1&service=WCS&coverage=sf__sfdem" localwcs.vrt
QGIS opens localwcs.vrt. The VRT file is referencing another XML file that is created by the WCS driver, in my case
<SourceFilename relativeToVRT="0">C:\Users\JRAHKONEN\.gdal\wcs_cache\DokaJ.xml</SourceFilename>
QGIS was not able to open C:\Users\JRAHKONEN\.gdal\wcs_cache\DokaJ.xml directly but I did not spend much time for finding out why not.
So if you want to continue the game:
1. create vrt with gdal_translate
2. check what xml file it is reading
3. move the xml file away from the WCS cache directory
4. edit the vrt file and update the reference into the XML file
5. Try with GDAL tools and QGIS.
I am not at all sure if QGIS can use the WCS-VRT layer in a way that makes sense. I suggest to test with your own Geoserver and follow what kind of requests QGIS creates.
Good luck.
-Jukka Rahkonen-
-Jukka Rahkonen-
Lähettäjä: 1520 gis <juliermeopensourcedeveloper at gmail.com>
Lähetetty: maanantai 23. marraskuuta 2020 16.01
Vastaanottaja: gdal-dev at lists.osgeo.org; Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
Aihe: Re: gdal-dev Digest, Vol 198, Issue 45
Dear Rahkonen Jukka,
I will consider your warnings about using GDAL_WCS with GeoServer. It seems that what I am trying to do is not possible, but it will be something interesting to achieve through GDAL_WCS. In many cases, the user has access to wcs geoservices and he may be interested in loading some specific coverages (full coverage and subsets) in QGIS using an XML just like GDAL_WMTS driver. Some institutions make WCS capabilities available, but wmts. And this is my situation, I have a remote / external geoserver with wcs capabilities available, but wmts.
It could be something interesting to be implemented in the future.
Thank you very much for your time and consideration of my messages.
Kind regards
Julierme
On Sat, Nov 21, 2020 at 5:00 PM <gdal-dev-request at lists.osgeo.org<mailto:gdal-dev-request at lists.osgeo.org>> wrote:
Send gdal-dev mailing list submissions to
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
To subscribe or unsubscribe via the World Wide Web, visit
https://lists.osgeo.org/mailman/listinfo/gdal-dev
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
gdal-dev-owner at lists.osgeo.org<mailto:gdal-dev-owner at lists.osgeo.org>
When replying, please edit your Subject line so it is more specific
than "Re: Contents of gdal-dev digest..."
Today's Topics:
1. GDAL_WCS Driver and gdal_translate (1520 gis)
2. Re: GDAL_WCS Driver and gdal_translate (jratike80)
3. Automatic labels placement (Franco Amato)
4. resampling netcdf data (Nazanin tavakoli)
Message: 1
Date: Fri, 20 Nov 2020 17:18:30 -0300
From: 1520 gis <juliermeopensourcedeveloper at gmail.com<mailto:juliermeopensourcedeveloper at gmail.com>>
To: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Subject: [gdal-dev] GDAL_WCS Driver and gdal_translate
Message-ID:
<CAKTKyJKpbfvZnXhM60FDF_T-0wFFpW=54wc8f1nnh5fZ7REm7A at mail.gmail.com<mailto:54wc8f1nnh5fZ7REm7A at mail.gmail.com>>
Content-Type: text/plain; charset="utf-8"
Dear all,
I would like to open this discussion here about creating a xml/ raster wcs
ingest using gdal_translate.
My 2 goals are:
1 - get a xml like in [1] by running command line similar do gdal_wmts
driver in [2]
gdal_translate "WCS:
http://demo.geo-solutions.it:80/geoserver/wcs?version=2.0.1&coverage=nurc__Img_Sample
<http://demo.geo-solutions.it/geoserver/wcs?version=2.0.1&coverage=nurc__Img_Sample>
" wcs.xml -of WCS
*OR*
http://demo.geo-solutions.it/geoserver/ows?service=WCS&request=getCapabilities,layer=nurc__Img_Sample
" wcs.xml -of WCS
2 - get a xml / raster subset
" wcs.xml -projwin -100 40 -80 30 -of WCS
*OR*
If the solution I am trying to get can not be possible through
gdal_translate, would someone have an xml sample like in [1] to share, but
with raster subset ingest, instead the whole image content?
I appreciated your time in advance.
Kind regards
Julierme
[1] <WCS_GDAL>
<ServiceURL>https://demo.geo-solutions.it/geoserver/wcs?version=2.0.1&
;</ServiceURL>
<CoverageName>nurc:Img_Sample</CoverageName>
<GetCoverageExtra>&BoundingBox=-130.85168,20.7052,-62.0054,54.1141</GetCoverageExtra>
</WCS_GDAL>
[2] gdal_translate "WMTS:
http://maps.wien.gv.at/wmts/1.0.0/WMTSCapabilities.xml,layer=lb" wmts.xml -
of WMTS.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201120/ca9ab931/attachment-0001.html>
Message: 2
Date: Sat, 21 Nov 2020 03:47:58 -0700 (MST)
From: jratike80 <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>>
Subject: Re: [gdal-dev] GDAL_WCS Driver and gdal_translate
Message-ID: <1605955678597-0.post at n6.nabble.com<mailto:1605955678597-0.post at n6.nabble.com>>
Content-Type: text/plain; charset=us-ascii
Just a note to remind that earlier in thread "gdal-dev Digest, Vol 198,
Issue 14" it was noticed that the GDAL WCS driver most probably has a bug
and certain WCS coverages from Geoserver do not work. It seems to be related
with the native CRS EPSG:4326. So if you test now with Geoserver, don't test
with nurc__Img_Sample or other coverages which are in EPSG:4326.
I know this does not answer your question, sorry.
-Jukka Rahkonen-
juliermeopensourcedeveloper wrote
> Dear all,
> My 2 goals are:
> driver in [2]
> " wcs.xml -of WCS
> *OR*
> " wcs.xml -of WCS
> *OR*
> Kind regards
> Julierme
> [1]
> <WCS_GDAL>
> <ServiceURL>
> </ServiceURL>
> <CoverageName>
> nurc:Img_Sample
> </CoverageName>
> <GetCoverageExtra>
> </GetCoverageExtra>
> </WCS_GDAL>
> of WMTS.
> gdal-dev at .osgeo<mailto:gdal-dev at .osgeo>
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
Message: 3
Date: Sat, 21 Nov 2020 09:59:01 -0500
From: Franco Amato <cvfrank at gmail.com<mailto:cvfrank at gmail.com>>
Subject: [gdal-dev] Automatic labels placement
Message-ID:
<CADAAwMcJMh6hS6HM1WKgjYKMJZXetgqYWRSOkfRw3e1LuCg2iw at mail.gmail.com<mailto:CADAAwMcJMh6hS6HM1WKgjYKMJZXetgqYWRSOkfRw3e1LuCg2iw at mail.gmail.com>>
Good morning gdal members,
I would know if you know any automatic labels placement library. I tried
with PAL library located here (http://pal.heig-vd.ch) but it's too complex
to use with GDAL data.
Any suggestions are really appreciated.
Thank you,
Franco
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201121/c0a10346/attachment-0001.html>
Message: 4
Date: Sat, 21 Nov 2020 18:47:18 +0330
From: Nazanin tavakoli <nazitkk1375 at gmail.com<mailto:nazitkk1375 at gmail.com>>
Subject: [gdal-dev] resampling netcdf data
Message-ID:
<CAPBJ=OxvAJgetPVmJ9hKx8nF9wE9xW3BXtFtzJPcZNfTk4xcwQ at mail.gmail.com<mailto:OxvAJgetPVmJ9hKx8nF9wE9xW3BXtFtzJPcZNfTk4xcwQ at mail.gmail.com>>
Hello,
I want to change the resolution of my data whose resolution is 0.0416
degrees (1/24th) resolution and I want to convert it to 0.5 degrees. I have
already used this code but I have some errors. Could you please help me?
gdal_translate -of netCDF -tr 0.5 0.5 WS.nc
<https://www.youtube.com/redirect?redir_token=QUFFLUhqa0hCWkdnLUttTmVYbzh4UGFIeW9RQTBxa2piUXxBQ3Jtc0trMTVQTV9YMVVrZWVzb2xXVjh1LVBCQ2ZoT3FoTzNKYjQ2NndBcmIxQVd2TkM3NXU3dUVjQ2FtMXFkOWdRSi1vdTVISnd6UEpsZWRDRVlLSDlzZDJlcGdqdlU5S0xyOXhXSlFSajliMG1URkhrWi1iMA%3D%3D&event=comments&q=http%3A%2F%2Fws.nc%2F&stzid=UgynaQQEp5-9sVSWQqp4AaABAg.9GHKHEPqQ8_9GKO25Kpqfy>
WS_1.nc
<https://www.youtube.com/redirect?redir_token=QUFFLUhqbEYxWEQxZzZpbVZSNGk2RjZHUnVUdEVNNEpZd3xBQ3Jtc0ttNzZDcUdxdUN6QU5vc1lKVmdULVFqLWo1WDdjendJbXJwcm03a3R2bWN6dnRlaWM1bENzUXhFNnp2NlN6b2x6Q0V3X21ueFdBNm5HVmQzaEVsZ0FKWGNZNEZSSk9GdDdmbVFwY2JKX1RuUjk0TTJTUQ%3D%3D&event=comments&q=http%3A%2F%2F1.nc%2F&stzid=UgynaQQEp5-9sVSWQqp4AaABAg.9GHKHEPqQ8_9GKO25Kpqfy>
Warning 1: Recode from UTF-8 to CP_ACP failed with the error: "Invalid
argument".
Warning 1: No UNIDATA NC_GLOBAL:Conventions attribute Input file size is
8640, 4320 0Warning 1: Recode from UTF-8 to CP_ACP failed with the error:
"Invalid argument". ...10...20...30...40...50...60...70...80...90..Warning
1: Recode from UTF-8 to CP_ACP failed with the error: "Invalid argument".
.100 - done.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201121/c8ee3be9/attachment-0001.html>
Subject: Digest Footer
End of gdal-dev Digest, Vol 198, Issue 45
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201123/24144386/attachment-0001.html>
