[gdal-dev] Improving NITF SICD support
Andrew Hardin
andrew.hardin5+gdaldev at gmail.com
Tue Nov 24 15:32:14 PST 2020
Hi all,
I'd like to improve derived dataset support for SICD files. Here's one of
the example files I'm working with:
https://six-library.s3.amazonaws.com/sicd_example_1_PFA_RE32F_IM32F_HH.nitf
This SICD file is a two-band NITF with an XML DES tacked onto the end. The
two bands are {inphase, quadrature} and together they represent complex
data. However, because they're in two separate bands, gdalinfo doesn't
report any of the standard DERIVED_SUBDATASET functions for the complex
data.
The desired end-state is to have standard DERIVED_SUBDATASET functions
available for two-band complex data NITFs. One implementation option(?)
would be to write a new driver for SICD that's a specialized wrapper around
a NITF dataset, but that feels heavy handed.
Any suggestions for how to go about this?
Thanks,
Andrew
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201124/d85a9dce/attachment.html>
