[gdal-dev] gdalwarp from EPSG:25832 to EPSG:4326 with error latitude or longitude exceeded limits?
Pham Huu Bang
a09550 at gmail.com
Wed Nov 25 02:00:42 PST 2020
Hi Tobias,
If I set to EPSG:4647, I cannot warp it either:
gdal_translate -a_srs EPSG:4647 test.tif test1.tif
Input file size is 100, 100
0...10...20...30...40...50...60...70...80...90...100 - done.
gdalinfo test1.tif
Driver: GTiff/GeoTIFF
Files: test1.tif
Size is 100, 100
Coordinate System is:
LOCAL_CS["ETRS89 / UTM zone 32N (zE-N)",
GEOGCS["ETRS89",
DATUM["unknown",
SPHEROID["unretrievable - using WGS84",6378137,298.257223563]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
AUTHORITY["EPSG","4647"],
UNIT["metre",1]]
Origin = (32573000.000000000000000,6019990.000000000000000)
Pixel Size = (10.000000000000000,-10.000000000000000)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left (32573000.000, 6019990.000)
Lower Left (32573000.000, 6018990.000)
Upper Right (32574000.000, 6019990.000)
Lower Right (32574000.000, 6018990.000)
Center (32573500.000, 6019490.000)
Band 1 Block=100x20 Type=Float32, ColorInterp=Gray
NoData Value=-9999
gdalwarp test1.tif -t_srs EPSG:4326 test2.tif
ERROR 1: No PROJ.4 translation for source SRS, coordinate
transformation initialization has failed.
On Wed, 25 Nov 2020 at 10:55, Tobias Wendorff <
tobias.wendorff at tu-dortmund.de> wrote:
> Am 25.11.2020 um 10:17 schrieb Pham Huu Bang:
> > Corner Coordinates:
> > Upper Left (32573000.000, 6019990.000) (174d17' 8.00"W,Invalid angle)
> > Lower Left (32573000.000, 6018990.000) (114d59' 0.99"W,Invalid angle)
> > Upper Right (32574000.000, 6019990.000) (109d46'37.15"W,Invalid angle)
> > Lower Right (32574000.000, 6018990.000) ( 43d35'46.10"W,Invalid angle)
> > Center (32573500.000, 6019490.000) (102d39' 0.67"W,Invalid angle)
> > NoData Value=-9999
> That's not EPSG:25832. It's EPSG:4647.
> xx359666.704;5651728.683 -> EPSG:25832
> 32359666.704;5651728.683 -> EPSG:4647
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201125/f42addbc/attachment.html>
