[gdal-dev] Using OSGeo's code of conduct for GDAL one (was Re: Adopting Contributor Covenant v2.0 as code of conduct)
Even Rouault
even.rouault at spatialys.com
Wed Nov 25 07:50:39 PST 2020
On mercredi 25 novembre 2020 09:36:03 CET Howard Butler wrote:
> > On Nov 25, 2020, at 9:34 AM, Mateusz Loskot <mateusz at loskot.net> wrote:
> > On Wed, 25 Nov 2020 at 15:13, Even Rouault <even.rouault at spatialys.com>
wrote:
> >> Honestly I don't really care about which CoC we select. We just need (a
> >> somewhat reasonable) one, and above all, not create a new one.
> > Yes, let's use the OSGeo's.
> Agree.
OK, so https://github.com/OSGeo/gdal/pull/3226
> I would add that the notification portion should direct people to contact
> OSGeo instead of any PSC members in the event that the PSC is the entity
> violating the CoC. This will also ensure that action is taken in regard to
> a notice rather than a PSC member simply stuffing it.
I haven't added anything specifically for that: the OSGeo's CoC page contains
the instructions.
Even
http://www.spatialys.com
