[gdal-dev] Broken PDF support due to Ubuntu 16.04 and 18.04 security updates [SOLVED]
Even Rouault
even.rouault at spatialys.com
Thu Nov 26 14:02:14 PST 2020
On jeudi 26 novembre 2020 15:45:40 CET Even Rouault wrote:
> Hi,
> FYI, the latest security updates on the Poppler library in Ubuntu 16.04 and
> 18.04 break GDAL PDF output.
> See https://github.com/OSGeo/gdal/pull/3235 for a workaround installing the
> previous functional versions.
> Issue reported upstream at
> https://bugs.launchpad.net/ubuntu/+source/poppler/+bug/1905741
The issue has been promptly fixed upstream and fixed packages are now
available.
Even
http://www.spatialys.com
