[gdal-dev] OGR fails to open a VRT layer with a remote data source if VSI_CACHE=TRUE
Andrea Giudiceandrea
andreaerdna at libero.it
Sun Oct 4 12:10:16 PDT 2020
Andrea Giudiceandrea wrote
> Could the issue be caused by a server misconfiguration or not suitable for
> this kind of use, or should it be fixed in GDAL/OGR?
Thank you Even Rouault for fixing the issue in GDAL/OGR, even if it was a
server side bug.
> Do you think the VSI_CACHE=TRUE 7 years old workaround setting is really
> still required on Windows (OSGeo4W), since in the meantime GDAL/OGR may
> have
> been improved in shapefile reading over network?
Anyway, what do you think about the default setting of VSI_CACHE=TRUE in
OSGeo4W QGIS? Is it really still required?
For reference, see
https://www.mail-archive.com/gdal-dev@lists.osgeo.org/msg18287.html,
https://issues.qgis.org/issues/6448
Best regards.
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
