[gdal-dev] Is it possible to use VRTDerivedRasterBand in VRTWarpedDataset?
Next Stop
nextstopsun at gmail.com
Thu Oct 8 05:03:54 PDT 2020
Hello,
I have two-band raster dataset, which I need to warp to another CRS, calculate a single band with a pixel function and apply a color lookup table to it, so the result is interpolated RGB color.
The result can be achieved by calling `gdalwarp` then `gdal_calc.py` and then `gdaldem color-relief` with a color LUT.
But I don't need any intermediate data. So I'm lookig for a way to define the whole workflow in a single VRT.
Is that possible?
So far I've created a VRTWarpedDataset, but when I try to reduce the number of bands to a single VRTDerivedRasterBand, I get an error:
ERROR 5: panDstBands[1] = 2 ... out of range for dataset.
When leaving second band, I get
Warning 1: Unable to export color table to GeoTIFF file. Color tables can only be written to 1 band or 2 bands Byte or UInt16 GeoTIFF files.
Also just adding a color table doesn't output 3-band RGB with color interpolation like `gdaldem color-relief`.
Can such interpolation be set up in VRT?
