[gdal-dev] WEBP in GEOTIFF
Andreas Neumann
a.neumann at carto.net
Fri Oct 9 06:06:37 PDT 2020
I am using a self-compiled GDAL 3.1.2 version and try to create a GTIFF
file with COMPRESS=WEBP
libwebp-devel and other webp automatic dependencies are installed on
this ubuntu 18.04 machine. I could also compile against libwebp
However, when running gdal_translate like
gdal_translate -b 1 -b 2 -b 3 -b mask -of GTIFF -co COMPRESS=WEBP -co
PHOTOMETRIC=YCBCR -co BLOCKXSIZE=512 -co BLOCKYSIZE=512 -co BIGTIFF=YES
-co NUM_THREADS=4 -a_srs EPSG:2056 -projwin 2599700 1226200 2602200
1224650 ch.swisstopo.orthofoto_2018.rgb.vrt test_webp_ycbcr.tif
I get the following error output:
Input file size is 530000, 480000
Warning 6: 'WEBP' is an unexpected value for COMPRESS creation option of
type string-select.
ERROR 1: Cannot create TIFF file due to missing codec for WEBP.
Any idea what might be missing in my installation - where do I get this
missing codec for WEBP?
Thanks,
Andreas
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201009/5cc78373/attachment.html>
