[gdal-dev] ogr2ogr: debugging slow performance when converting .e00 to other formats
Jed O. Kaplan jed.kaplan at arve-research.com
Mon Oct 12 18:43:00 PDT 2020
Thanks for the help all.
Using avcimport to convert the .e00 to binary coverages allowed me to convert to other formats in seconds. I should have thought of this.
Thanks again, Jed
> On 13 Oct 2020, at 07:02, Even Rouault <even.rouault at spatialys.com> wrote:
> > Another option is to use QGIS to convert it.
> > That may be the best option for you.
> This is unlikely to help. QGIS uses the OGR AVCE00 driver underneath.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
