[gdal-dev] [QGIS-Developer] QGIS from OSGeo4W crashes with latest update on NetCDF
Even Rouault
even.rouault at spatialys.com
Tue Oct 20 10:08:10 PDT 2020
On mardi 20 octobre 2020 16:12:56 CEST Pedro Venâncio wrote:
> Hi Joaquim Luís,
> This is an IPMA NetCDF, it was working before the update.
> And I think it is in fact a HDF5 library version problem:
> > gdalinfo AROME_OPER_001_FC_SP_PT2_025_RH_2-HTGL_2020102000.nc
> Warning 1: Recode from UTF-8 to CP_ACP failed with the error: "Invalid
> argument".
> Warning! ***HDF5 library version mismatched error***
Jürgen told me that he has rebuilt the netCDF lib against the new HDF5 lib, so
hopefully if you update your OSGeo4W install (to netcdf 4.6.2-2 I think), that
should work now.
http://www.spatialys.com
