[gdal-dev] DXF Writer: Problem with convert the hexadecimal color
jlaegel
jlaegel at gbi-info.de
Wed Oct 21 01:17:59 PDT 2020
Hello,
I use in "ogr_style" following color: RGB 198,228,211 (HEX: #c6e4d3).
In the created DXf-File the color is the index color 254 (RGB: 214,214,214)
But, when i use the color RGB 127,255,127 (#7fff7f, equal to index number
91) it works in the DXF.
Can i use for DXf-Writer only index color values?
OR: How can i use a true color values?
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
