[gdal-dev] Apply Vertical Grid Shift to coordinate
Even Rouault
even.rouault at spatialys.com
Thu Oct 22 12:09:40 PDT 2020
> echo 7.4474 46.9480 590 2020 | cct +proj=vgridshift
> +grids=./geoid+HTRANS_ETRS2020.gtx
> 7.4474000000 46.9480000000 -inf 2020.0000
Check what "gdalinfo geoid+HTRANS_ETRS2020.gtx" reports as extent (so this now
becomes relevant to this mailing list ;-))
And if that seems OK, try also:
gdallocationinfo -geoloc geoid+HTRANS_ETRS2020.gtx 7.4474 46.9480
The -inf value is intriguing. Normally if you're out of bounds, cct
shoud report an error message "(point not within available datum shift grids)"
I was wondering if the + in the filename wouldn't confused PROJ, but on a
quick try with another gtx file, that seems fine.
Even
http://www.spatialys.com
