[gdal-dev] Apply Vertical Grid Shift to coordinate
Even Rouault
even.rouault at spatialys.com
Thu Oct 22 13:17:24 PDT 2020
> $ head geoid+HTRANS_ETRS2020.gtx
> 45.75 5.85 0.00833333333333333333 0.00833333333333333333 253 559
> 49.4610
> 49.4649
> 49.4720
> 49.4823
> 49.5021
> 49.5511
> 49.5899
> 49.5819
> 49.5588
This is definitely not a GTX file. GTX is a binary format. I don't think
there's an existing GDAL driver for the above variant.
You'll have to write your own convertion script or modify the file to look
like something recognized by GDAL, like a AAIGRID file. Or yell at the person
who provided that file to you to not use something known by GDAL.
The header line is likely:
south_latitude (I guess for Switzerland)
west_longitude
vertical_resolution (or horizontal_resolution ?)
horizontal_resolution (or vertical_resolution ?)
height_in_pixels (or width_in_pixels ?)
width_in_pixels (or height_in_pixels ?)
If you map that to headers of AAIGRID, that could work. That looks like:
ncols 20
nrows 20
xllcorner 440720.000000000000
yllcorner 3750120.000000000000
cellsize 60.000000000000
You'll perhaps have to do a vertical flip depending on the convention of your
file (can be done for example by switching top and bottom Y with
gdal_translate -a_ullr and then gdalwarp)
Even
http://www.spatialys.com
