[gdal-dev] Dirty block GDALRasterBand::IRasterIO error even with Libtiff > 4.0 on Windows and Mac but not Linux.
Krishna Bhogaonker cyclotomiq at gmail.com
Fri Oct 23 08:47:51 PDT 2020
Hello folks.
This is my first post to the GDAL list :). So I am running into an error
using `Rasterio` 1.1.7 and `Gdal` 3.1.3 on Windows and Mac, but not Linux.
The code opens a raster GeoTIFF file and compresses the data to some
smaller format. Here is the code below and then a picture of the error
message. Note that the code is written in Python 3.8 with `rasterio` but
the error seems to come from the GDAL call.
The error message is rasterio.errors.RasterioIOError: Read or write failed.
An error occurred while writing a dirty block from
GDALRasterBand::IRasterIO . I googled around and found that I needed to
ensure Libtiff > 4.0 is installed, which I did--but the error still
persists.
One thing to note is that the GeoTIFF is rather large. I am working with
aerial drone imagery for a philanthropic group in Tanzania, so the images
can be like 2-6GB even after compressed. Here is a sample image that I use
for testing
https://github.com/00krishna-tools/nyuki/releases/download/v0.0.1/sample_image_big.tif
import rasterio
dat = 'sample_image_big.tif'
target_file = 'sample_image_big_compressed_jpeg.tif'
with rasterio.Env():
    profile.update(
        compress="JPEG",
        BIGTIFF = "YES")
    with rasterio.open(target_file, 'w', **profile) as dst:
        for ji, window in dat.block_windows(1):
            dst.write(dat.read(window=window), window=window)
I am using "windowed" reads and writes, etc., so that seems to be the
most efficient way to do it.
Here is a picture of the error with traceback:
  File "rasterio/_io.pyx", line 1369, in rasterio._io.DatasetWriterBase.write
  File "rasterio/shim_rasterioex.pxi", line 133, in rasterio._shim.io_multi_band
  File "rasterio/_err.pyx", line 182, in rasterio._err.exc_wrap_int
rasterio._err.CPLE_AppDefinedError: An error occurred while writing a
dirty block from GDALRasterBand::IRasterIODuring handling of the above
exception, another exception occurred:Traceback (most recent call
last):
  File "/Users/user/mdconda/anaconda3/envs/nyuki-env/bin/nyuki", line
10, in <module>
    sys.exit(nyuki())
  File "/Users/user/mdconda/anaconda3/envs/nyuki-env/lib/python3.7/site-packages/click/core.py",
line 829, in __call__
    return self.main(*args, **kwargs)
line 782, in main
    rv = self.invoke(ctx)
line 1259, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
line 1066, in invoke
    return ctx.invoke(self.callback, **ctx.params)
line 610, in invoke
    return callback(*args, **kwargs)
  File "/Users/user/mdconda/anaconda3/envs/nyuki-env/lib/python3.7/site-packages/nyuki/nyuki.py",
line 160, in compress
    compressor(sourcetiff, target_compression, yes)
  File "/Users/user/mdconda/anaconda3/envs/nyuki-env/lib/python3.7/site-packages/nyuki/geotiff_compressor.py",
line 52, in compressor
  File "rasterio/_io.pyx", line 1371, in rasterio._io.DatasetWriterBase.write
rasterio.errors.RasterioIOError: Read or write failed. An error
occurred while writing a dirty block from GDALRasterBand::IRasterIO
So the real question is whether there is a workaround for this issue,
or is there something different
I should do with my code? Any suggestions for getting this code to
work on Mac and Windows, as it
works just fine on Linux. Thanks so much for any insights.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201023/e4566224/attachment-0001.html>
