[gdal-dev] GetProjection returns empty string, python 3.7
Paul Harwood
runette at gmail.com
Mon Oct 26 12:44:10 PDT 2020
I am not sure why you are using GetProjection and not GetSpatialRef ?
Although, the code snippet you included in your email does not seem to use
either?
I certainly was in the process of working on some code that uses
.GeoSptialRef very successfully on GDAL3.1.3 - so I am sure that it is
working!
On Mon, 26 Oct 2020 at 18:36, Nicolas Cadieux <njacadieux.gitlab at gmail.com>
wrote:
> New info!
> GetProjection works with gdal python 2.2.2 and 2.3.3 but not with with
> gdal 3.0.2. Is this a change in the gdal library?
> Nicolas
> On 2020-10-26 1:53 p.m., Nicolas Cadieux wrote:
> > Hi,
> > In case mail question was not clear, I have posted the questions about
> > this on stackexchange. I posted a full code that you can run exposing
> > my problem and question.
> > Thanks
> > Nicolas
> https://gis.stackexchange.com/questions/377567/cannot-get-projection-from-raster-dataset-using-getprojection
> > On 2020-10-25 9:31 p.m., Nicolas Cadieux wrote:
> >> Hi,
> >> With the following code, I get an empty string indicating the
> >> projection is not valid.
> >> from osgeo import gdal, osr
> >> raster_ds = gdal.Open(r"C:\temp\180922_WTE3.tif")
> >> target_ds =
> driver.Create(r"c:\temp\output.tif",xsize=raster_ds_ncol,ysize=raster_ds_nrow,bands
> >> = 1,eType = gdal.GDT_Float32)
> >> (array is a numpty array.)
> >> raster_srs = osr.SpatialReference()
> >> raster_srs.ImportFromWkt(raster_ds.GetProjectionRef())
> >> target_ds.SetProjection(raster_srs.ExportToWkt())
> >> target_ds.GetRasterBand(1).WriteArray(array)
> >> raster_ds = None #close dataset
> >> target_ds=None
> >> Below is the result of gdal info from qgis. File appears to have a
> >> valid projection and is properly georeferenced in QGIS using other
> >> data sets. Is this projection wrong or am I missing something in my
> >> python code? The goal is to extract the projection from raster_ds
> >> set in order to apply to target_ds. I can create the file, apply a
> >> geotransform but can't get the projection. Can you help?
> >> Thanks/merci!
> >> Nicolas
> >> QGIS version: 3.14.16-Pi
> >> QGIS code revision: df27394552
> >> Qt version: 5.11.2
> >> GDAL version: 3.0.4
> >> GEOS version: 3.8.1-CAPI-1.13.3
> >> PROJ version: Rel. 6.3.2, May 1st, 2020
> >> Processing algorithm…
> >> Algorithm 'Raster information' starting…
> >> Input parameters:
> >> { 'EXTRA' : '', 'INPUT' : 'C:/temp/180922_WTE3.tif', 'MIN_MAX' :
> >> False, 'NOGCP' : False, 'NO_METADATA' : False, 'OUTPUT' :
> >> 'TEMPORARY_OUTPUT', 'STATS' : False }
> >> GDAL command:
> >> gdalinfo C:/temp/180922_WTE3.tif
> >> GDAL command output:
> >> Warning 1: TIFFReadDirectory:Sum of Photometric type-related color
> >> channels and ExtraSamples doesn't match SamplesPerPixel. Defining
> >> non-color channels as ExtraSamples.
> >> Driver: GTiff/GeoTIFF
> >> Files: C:/temp/180922_WTE3.tif
> >> Size is 1194, 2783
> >> Coordinate System is:
> >> PROJCRS["WGS 84 / UTM zone 18N",
> >> BASEGEOGCRS["WGS 84",
> >> DATUM["World Geodetic System 1984",
> >> ELLIPSOID["WGS 84",6378137,298.257223563,
> >> LENGTHUNIT["metre",1]]],
> >> PRIMEM["Greenwich",0,
> >> ANGLEUNIT["degree",0.0174532925199433]],
> >> ID["EPSG",4326]],
> >> CONVERSION["UTM zone 18N",
> >> METHOD["Transverse Mercator",
> >> ID["EPSG",9807]],
> >> PARAMETER["Latitude of natural origin",0,
> >> ANGLEUNIT["degree",0.0174532925199433],
> >> ID["EPSG",8801]],
> >> PARAMETER["Longitude of natural origin",-75,
> >> ID["EPSG",8802]],
> >> PARAMETER["Scale factor at natural origin",0.9996,
> >> SCALEUNIT["unity",1],
> >> ID["EPSG",8805]],
> >> PARAMETER["False easting",500000,
> >> LENGTHUNIT["metre",1],
> >> ID["EPSG",8806]],
> >> PARAMETER["False northing",0,
> >> ID["EPSG",8807]]],
> >> CS[Cartesian,2],
> >> AXIS["(E)",east,
> >> ORDER[1],
> >> LENGTHUNIT["metre",1]],
> >> AXIS["(N)",north,
> >> ORDER[2],
> >> USAGE[
> >> SCOPE["unknown"],
> >> AREA["World - N hemisphere - 78°W to 72°W - by country"],
> >> BBOX[0,-78,84,-72]],
> >> ID["EPSG",32618]]
> >> Data axis to CRS axis mapping: 1,2
> >> Origin = (459417.200000000011642,5028584.700000000186265)
> >> Pixel Size = (0.050000000000000,-0.050000000000000)
> >> Metadata:
> >> AREA_OR_POINT=Area
> >> TIFFTAG_XRESOLUTION=1
> >> TIFFTAG_YRESOLUTION=1
> >> Image Structure Metadata:
> >> INTERLEAVE=BAND
> >> Corner Coordinates:
> >> Upper Left ( 459417.200, 5028584.700) ( 75d31' 7.03"W, 45d24'34.58"N)
> >> Lower Left ( 459417.200, 5028445.550) ( 75d31' 6.99"W, 45d24'30.07"N)
> >> Upper Right ( 459476.900, 5028584.700) ( 75d31' 4.28"W, 45d24'34.59"N)
> >> Lower Right ( 459476.900, 5028445.550) ( 75d31' 4.24"W, 45d24'30.08"N)
> >> Center ( 459447.050, 5028515.125) ( 75d31' 5.63"W, 45d24'32.33"N)
> >> Band 1 Block=1194x1 Type=UInt16, ColorInterp=Red
> >> Band 288 Block=1194x1 Type=UInt16, ColorInterp=Undefined
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201026/d72156d4/attachment.html>
