[gdal-dev] GetProjection returns empty string, python 3.7
Nicolas Cadieux njacadieux.gitlab at gmail.com
Mon Oct 26 16:00:55 PDT 2020
I am currently on 3.0.2.  and the Anaconda Navigator does not give me
higher options.  I will create a new clean environments and try conda
install.  I will try changing the code I think my version of the code
probably corresponds to <3 versions of gdal.  It's a cut and paste from
the gdal tutorial. Can I send you my test file to test on your code?
Thanks, I appreciate the help.
Nicolas
On 2020-10-26 6:31 p.m., Paul Harwood wrote:
> Me too.
> But which conda package for gdal are you using - there are a lot of
> ones out there.
> Are you using conda install -c conda-forge gdal ?
> It should be version 3.1.4 at the moment ?
> Also - I don't know if this is part of it but ...
> "srs = osr.SpatialReference()
> srs.SetUTM(11, 1)
> srs.SetWellKnownGeogCS("NAD27")
> dst_ds.SetProjection(srs.ExportToWkt())
> why not just
> srs.SetUTM(11, 1)
> dst_ds.SetSpatialRef(srs)
> On Mon, 26 Oct 2020 at 22:11, Nicolas Cadieux
> <njacadieux.gitlab at gmail.com <mailto:njacadieux.gitlab at gmail.com>> wrote:
>     Hi,
>     Comes back as None for me... :(  I'am working with Anaconda.
>     Could it be my environment?
>     Nicolas
>     On 2020-10-26 5:04 p.m., Paul Harwood wrote:
>>     GetSpatialRef is OSR based and it is certainly working for me
>>     against GDAL Raster datasets - it would not be a method against
>>     the GDAL Dataset if it was only an OGR thing - OGR has its own
>>     objects.
>>     This code is working for me at this very minute and giving me the
>>     name of the CRS for a gtiff
>>     dataset = gdal.Open(str(filepath))
>>             if dataset:
>>                 proj = "None"
>>                 crs = dataset.GetSpatialRef()
>>                 if crs:
>>                     proj = crs.GetName()
>>                 return {"type": "gdal", "driver":
>>     dataset.GetDriver().ShortName, "proj": proj}
>>     On Mon, 26 Oct 2020 at 20:08, Nicolas Cadieux
>>         Hi,
>>         Thanks for helping.  I will put my code at the end.  The
>>         problem seems to be between gdal python lib 2.2.2 and 3.0.2.
>>         Under 2.2.2 and < 3, GetProjection() works well but return
>>         nothing with gdal python lib 3.0.2.  It's my understanding
>>         that .GetSpatialRef is for OGR data (vector).  Am I wrong?
>>         I was using GetProjection() because that is the method used
>>         in the raster_api tutorial.
>>         (https://gdal.org/tutorials/raster_api_tut.html)
>>         I understand that gdal 3 now relies on proj 6 for the
>>         SpatialRef.  I'am trying to figure out if is a problem with
>>         proj or with gdal...
>>         Nicolas
>>         code:
>>         # -*- coding: utf-8 -*-
>>         Created on Sun Oct 25 15:09:05 2020
>>         @author: Nicolas
>>         #https://stackoverflow.com/questions/37648439/simplest-way-to-save-array-into-raster-file-in-python
>>         from osgeo import gdal, osr, ogr
>>         import numpy
>>         print (gdal.__version__)
>>         # https://gdal.org/tutorials/raster_api_tut.html
>>         fileformat = "GTiff"
>>         driver = gdal.GetDriverByName(fileformat)
>>         metadata = driver.GetMetadata()
>>         if metadata.get(gdal.DCAP_CREATE) == "YES":
>>             print("Driver {} supports Create()
>>         method.".format(fileformat))
>>         if metadata.get(gdal.DCAP_CREATECOPY) == "YES":
>>             print("Driver {} supports CreateCopy()
>>         dst_ds = driver.Create(r"c:\temp\gdal.tif", xsize=512, ysize=512,
>>                             bands=1, eType=gdal.GDT_Byte)
>>         dst_ds.SetGeoTransform([444720, 30, 0, 3751320, 0, -30])
>>         srs.SetUTM(11, 1)
>>         print ('srs = ',srs)# this is good
>>         raster = numpy.zeros((512, 512), dtype=numpy.uint8)
>>         dst_ds.GetRasterBand(1).WriteArray(raster)
>>         # Once we're done, close properly the dataset
>>         srs = None
>>         dst_ds = None #srs is file and well georeferenced in Qgis.
>>         # open dataset try to read srs
>>         raster_ds = gdal.Open(r"C:\temp\gdal.tif")
>>         # first try
>>         print("Projection is {}".format(raster_ds.GetProjection()))
>>         # second try
>>         srs.ImportFromWkt(raster_ds.GetProjectionRef())
>>         print ('srs =', srs)
>>         # thrid try
>>         srs = raster_ds.GetProjection()
>>         print('srs =', srs)
>>         srs = raster_ds.GetProjectionRef()
>>         # forth try
>>         # from gdal_info
>>         https://github.com/OSGeo/gdal/blob/master/gdal/swig/python/samples/gdalinfo.py
>>         pszProjection = raster_ds.GetProjectionRef()
>>         print(pszProjection)
>>         if pszProjection is not None:
>>             hSRS = osr.SpatialReference()
>>             if hSRS.ImportFromWkt(pszProjection) == gdal.CE_None:
>>                 pszPrettyWkt = hSRS.ExportToPrettyWkt(False)
>>                 print("Coordinate System is:\n%s" % pszPrettyWkt)
>>             else:
>>                 print("Coordinate System is `%s'" % pszProjection)
>>         On 2020-10-26 3:44 p.m., Paul Harwood wrote:
>>>         I am not sure why you are using GetProjection and not
>>>         GetSpatialRef ? Although, the code snippet you included in
>>>         your email does not seem to use either?
>>>         I certainly was in the process of working on some code that
>>>         uses .GeoSptialRef very successfully on GDAL3.1.3 - so I am
>>>         sure that it is working!
>>>         On Mon, 26 Oct 2020 at 18:36, Nicolas Cadieux
>>>             New info!
>>>             GetProjection works with gdal python 2.2.2 and 2.3.3 but
>>>             not with with
>>>             gdal 3.0.2.  Is this a change in the gdal library?
>>>             Nicolas
>>>             On 2020-10-26 1:53 p.m., Nicolas Cadieux wrote:
>>>             > Hi,
>>>             > In case mail question was not clear, I have posted the
>>>             questions about
>>>             > this on stackexchange.  I posted a full code that you
>>>             can run exposing
>>>             > my problem and question.
>>>             > Thanks
>>>             > Nicolas
>>>             https://gis.stackexchange.com/questions/377567/cannot-get-projection-from-raster-dataset-using-getprojection
>>>             > On 2020-10-25 9:31 p.m., Nicolas Cadieux wrote:
>>>             >> Hi,
>>>             >> With the following code, I get an empty string
>>>             indicating the
>>>             >> projection is not valid.
>>>             >> raster_ds = gdal.Open(r"C:\temp\180922_WTE3.tif")
>>>             >> target_ds =
>>>             driver.Create(r"c:\temp\output.tif",xsize=raster_ds_ncol,ysize=raster_ds_nrow,bands
>>>             >> = 1,eType = gdal.GDT_Float32)
>>>             >> (array is a numpty array.)
>>>             >> raster_srs = osr.SpatialReference()
>>>             >> raster_srs.ImportFromWkt(raster_ds.GetProjectionRef())
>>>             >> target_ds.SetProjection(raster_srs.ExportToWkt())
>>>             >> target_ds.GetRasterBand(1).WriteArray(array)
>>>             >> raster_ds = None #close dataset
>>>             >> target_ds=None
>>>             >> Below is the result of gdal info from qgis. File
>>>             appears to have a
>>>             >> valid projection and is properly georeferenced in
>>>             QGIS using other
>>>             >> data sets.   Is this projection wrong or am I missing
>>>             something in my
>>>             >> python code?  The goal is to extract the projection
>>>             from raster_ds
>>>             >> set in order to apply to target_ds. I can create the
>>>             file, apply a
>>>             >> geotransform but can't get the projection.  Can you help?
>>>             >> Thanks/merci!
>>>             >> Nicolas
>>>             >> QGIS version: 3.14.16-Pi
>>>             >> QGIS code revision: df27394552
>>>             >> Qt version: 5.11.2
>>>             >> GDAL version: 3.0.4
>>>             >> GEOS version: 3.8.1-CAPI-1.13.3
>>>             >> PROJ version: Rel. 6.3.2, May 1st, 2020
>>>             >> Processing algorithm…
>>>             >> Algorithm 'Raster information' starting…
>>>             >> Input parameters:
>>>             >> { 'EXTRA' : '', 'INPUT' : 'C:/temp/180922_WTE3.tif',
>>>             'MIN_MAX' :
>>>             >> False, 'NOGCP' : False, 'NO_METADATA' : False,
>>>             'OUTPUT' :
>>>             >> 'TEMPORARY_OUTPUT', 'STATS' : False }
>>>             >> GDAL command:
>>>             >> gdalinfo C:/temp/180922_WTE3.tif
>>>             >> GDAL command output:
>>>             >> Warning 1: TIFFReadDirectory:Sum of Photometric
>>>             type-related color
>>>             >> channels and ExtraSamples doesn't match
>>>             SamplesPerPixel. Defining
>>>             >> non-color channels as ExtraSamples.
>>>             >> Driver: GTiff/GeoTIFF
>>>             >> Files: C:/temp/180922_WTE3.tif
>>>             >> Size is 1194, 2783
>>>             >> PROJCRS["WGS 84 / UTM zone 18N",
>>>             >> BASEGEOGCRS["WGS 84",
>>>             >> DATUM["World Geodetic System 1984",
>>>             >> ELLIPSOID["WGS 84",6378137,298.257223563,
>>>             >> LENGTHUNIT["metre",1]]],
>>>             >> PRIMEM["Greenwich",0,
>>>             >> ANGLEUNIT["degree",0.0174532925199433]],
>>>             >> ID["EPSG",4326]],
>>>             >> CONVERSION["UTM zone 18N",
>>>             >> METHOD["Transverse Mercator",
>>>             >> ID["EPSG",9807]],
>>>             >> PARAMETER["Latitude of natural origin",0,
>>>             >> ANGLEUNIT["degree",0.0174532925199433],
>>>             >> ID["EPSG",8801]],
>>>             >> PARAMETER["Longitude of natural origin",-75,
>>>             >> ID["EPSG",8802]],
>>>             >> PARAMETER["Scale factor at natural origin",0.9996,
>>>             >> SCALEUNIT["unity",1],
>>>             >> ID["EPSG",8805]],
>>>             >> PARAMETER["False easting",500000,
>>>             >> LENGTHUNIT["metre",1],
>>>             >> ID["EPSG",8806]],
>>>             >> PARAMETER["False northing",0,
>>>             >> ID["EPSG",8807]]],
>>>             >> CS[Cartesian,2],
>>>             >> AXIS["(E)",east,
>>>             >> ORDER[1],
>>>             >> LENGTHUNIT["metre",1]],
>>>             >> AXIS["(N)",north,
>>>             >> ORDER[2],
>>>             >> USAGE[
>>>             >> SCOPE["unknown"],
>>>             >> AREA["World - N hemisphere - 78°W to 72°W - by country"],
>>>             >> BBOX[0,-78,84,-72]],
>>>             >> ID["EPSG",32618]]
>>>             >> Data axis to CRS axis mapping: 1,2
>>>             >> Origin = (459417.200000000011642,5028584.700000000186265)
>>>             >> Pixel Size = (0.050000000000000,-0.050000000000000)
>>>             >> Metadata:
>>>             >> AREA_OR_POINT=Area
>>>             >> TIFFTAG_XRESOLUTION=1
>>>             >> TIFFTAG_YRESOLUTION=1
>>>             >> Image Structure Metadata:
>>>             >> INTERLEAVE=BAND
>>>             >> Corner Coordinates:
>>>             >> Upper Left ( 459417.200, 5028584.700) ( 75d31'
>>>             7.03"W, 45d24'34.58"N)
>>>             >> Lower Left ( 459417.200, 5028445.550) ( 75d31'
>>>             6.99"W, 45d24'30.07"N)
>>>             >> Upper Right ( 459476.900, 5028584.700) ( 75d31'
>>>             4.28"W, 45d24'34.59"N)
>>>             >> Lower Right ( 459476.900, 5028445.550) ( 75d31'
>>>             4.24"W, 45d24'30.08"N)
>>>             >> Center ( 459447.050, 5028515.125) ( 75d31' 5.63"W,
>>>             45d24'32.33"N)
>>>             >> Band 1 Block=1194x1 Type=UInt16, ColorInterp=Red
>>>             >> Band 288 Block=1194x1 Type=UInt16, ColorInterp=Undefined
>>>             _______________________________________________
>>>             gdal-dev mailing list
>>>             gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>>>             https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201026/742f27ee/attachment-0001.html>
