[gdal-dev] Motion: promote GDAL 3.2.0 RC1
Sean Gillies
sean at mapbox.com
Thu Oct 29 15:20:28 PDT 2020
On Thu, Oct 29, 2020 at 3:15 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Sean,
> > In rasterio's tests I have noticed a change in the order of coordinates
> in
> > the interior rings of polygons extracted by GDAL's polygonizer and a
> change
> > in the number of polygons extracted, but no other issues. I don't think
> > these need to hold up the release.
> Hum, changes in the order of coordinates are expected due to a change in
> the
> algorithm. GDAL autotest had to be adapted for that
> https://github.com/OSGeo/gdal/commits/c3a6bf99e3fd7fec4e11f9d1910e200b82742a5d
> . (testing with GEOSEquals_r() would be even more robust)
> But I wouldn't have necessarily expected a change in the number of
> polygons.
> Does the new result look correct ?
> Even
I misread my pytest output. It was only the JSON formatting of the polygon
that changed, the number of polygons is unchanged. Sorry for the false
alarm.
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201029/4233776e/attachment.html>
