[gdal-dev] RGDAL + sqlite3 = ld: cannot find -lsqlite3
Doug Niven
dniven at ucsc.edu
Fri Oct 30 09:35:55 PDT 2020
I’m hoping someone might be able to shed some light on how to fix the following message when installing ‘rgdal’:
/opt/rh/devtoolset-8/root/usr/libexec/gcc/x86_64-redhat-linux/8/ld: cannot find -lsqlite3
collect2: error: ld returned 1 exit status
GDAL, PROJ, GEOS, Postgres 9-11, all installed via Yum on Centos 7.
Sqlite3’s lib is in my LD_LIBRARY_PATH:
[root at localhost ~]# echo $LD_LIBRARY_PATH
/usr/sqlite330/lib:/opt/rh/llvm-toolset-7/root/usr/lib64:/opt/rh/devtoolset-8/root/usr/lib64:/opt/rh/devtoolset-8/root/usr/lib:/opt/rh/devtoolset-8/root/usr/lib64/dyninst:/opt/rh/devtoolset-8/root/usr/lib/dyninst:/opt/rh/devtoolset-8/root/usr/lib64:/opt/rh/devtoolset-8/root/usr/lib
And Sqlite3 is on my PATH:
[root at localhost ~]# which sqlite3
/usr/sqlite330/bin/sqlite3
Command to install used in R:
install.packages('rgdal', type = "source", configure.args=c('--with-gdal-config=/usr/gdal31/bin/gdal-config-64','--with-proj-include=/usr/proj71/include','--with-proj-lib=/usr/proj71/lib’))
Many thanks for any assistance with this!
Doug
