Solved I had a curl path problem. In my debian I have solved with sudo ln -s /usr/lib/x86_64-linux-gnu/libcurl.so.4.6.0 /usr/local/lib/libcurl.so Thank you jeff -- Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
