[gdal-dev] Compiling GDAL with Visual Studio 2019
Alexis Vaisse
alexis.vaisse at wysilab.com
Tue Sep 8 05:50:07 PDT 2020
Thanks.
I tried to follow your suggestion, updated nmake.opt, added the PROJ library and here is what I get:
D:\Terrain\Extern\gdal-3.1.3>nmake -f makefile.vc MSVC_VER=1927 WIN64=1
Microsoft (R) Program Maintenance Utility Version 14.27.29110.0
Copyright (C) Microsoft Corporation. All rights reserved.
cd port
nmake /nologo /f makefile.vc
call prev_dllbuild.bat
The system cannot find the path specified.
D:\Terrain\Extern\gdal-3.1.3\port>IF NOT EXIST dllbuild.prev (ECHO 1 ) 1>dllbuild.prev
D:\Terrain\Extern\gdal-3.1.3\port>SET /P PREV_DLLBUILD= 0<dllbuild.prev
D:\Terrain\Extern\gdal-3.1.3\port>IF NOT "1" == "1" (ECHO 1 ) 1>dllbuild.prev
NMAKE : fatal error U1077: 'call' : return code '0x1'
Stop.
NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.27.29110\bin\HostX64\x64\nmake.EXE"' : return code '0x2'
Stop.
Alexis Vaisse
Wysilab
-----Message d'origine-----
De : gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] De la part de Mateusz Loskot
Envoyé : mardi 8 septembre 2020 11:38
À : gdal-dev at lists.osgeo.org
Objet : Re: [gdal-dev] Compiling GDAL with Visual Studio 2019
On Tue, 8 Sep 2020 at 11:26, Alexis Vaisse <alexis.vaisse at wysilab.com> wrote:
> I’m trying to compile GDAL with Visual Studio 2019.
> The batch file to generate the project runs with no error. But when I try to compile the project, I get so many different errors I guess I did something wrong, but I don’t know what.
> Did somebody already succeed in compiling GDAL for Visual Studio 2019?
Yes, many times.
First, you don't have to generate .vcxproj files with the .bat script
to build GDAL.
Just run `nmake.exe` command in the VS Command Prompt.
However, before you attempt to build GDAL, you need to:
- Read https://trac.osgeo.org/gdal/wiki/BuildingOnWindows
- Check also https://trac.osgeo.org/gdal/wiki/BuildHints for specific
needs/dependencies/drivers
- Collect dependencies you require
- Edit nmake.opt to disable/enable features/drivers you don't
need/need, you have third-party dependencies for, etc.
- Run NMAKE
GDAL is not a self-contained project.
GDAL has numerous dependencies that you need to provide/install,
On Windows, manual editing of nmake.opt to configure your build is necessary.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
