[gdal-dev] Adding input format (-if) option for gdalmdiminfo and gdalmdimtranslate?
Joe Lee hyoklee at hdfgroup.org
Tue Sep 8 09:14:41 PDT 2020
Thank you for your quick reply!
I'll try my best to add them.
Sent: Tuesday, September 08, 2020 10:56 AM
To: gdal-dev at lists.osgeo.org
Cc: Joe Lee <hyoklee at hdfgroup.org>
Subject: Re: [gdal-dev] Adding input format (-if) option for gdalmdiminfo and gdalmdimtranslate?
On mardi 8 septembre 2020 09:27:19 CEST H. Joe Lee wrote:
> Hi,
> I can see that -if option is being [1] added to GDAL utilities, which is
> great for reading CF-compliant HDF5 as netCDF-4 and vice versa.
> Do you know how much effort is needed to apply the same -if option to
> Is adding the -if option in the current plan for next release?
Joe,
this shouldn't be too hard to do if you want to tackle that and submit a pull request.
You can take inspiration from
https://github.com/OSGeo/gdal/commit/1c7b950fc8754f6ba1d027f031886063675d2927
which added support for -if in gdalinfo, etc.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200908/44236185/attachment.html>
