[gdal-dev] Compiling GDAL with Visual Studio 2019
Alexis Vaisse
alexis.vaisse at wysilab.com
Wed Sep 9 07:41:26 PDT 2020
I get the help content, but also the strange message "The system cannot find the path specified" again.
I guess it's a problem with my Visual Studio installation.
I tried on another computer and this time everything ran fine. I will use the libraries generated on this computer, that's an acceptable workaround.
Thanks a lot for your help.
Alexis
-----Message d'origine-----
De : gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] De la part de Jeff McKenna
Envoyé : mardi 8 septembre 2020 18:07
À : gdal-dev at lists.osgeo.org
Objet : Re: [gdal-dev] Compiling GDAL with Visual Studio 2019
On 2020-09-08 12:24 p.m., Alexis Vaisse wrote:
> I started from a fresh copy of GDAL 3.1.3, so there should be nothing clean.
> Interestingly, I get the same kind of errors when calling nmake /f makefile.vc clean:
Interesting. I bet you get the same error with the command: help call
(the response is supposed to be: "Calls one batch program from another")
-jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
