[gdal-dev] ogr2ogr with ORACLE driver: limitation on table name size?
Ivan Lucena
ivan.lucena at outlook.com
Tue Sep 15 07:51:19 PDT 2020
Even,
You are correct.
As you can see in the code above those lines is that it is possible to run in debugging mode to check if the call to OCIServerVersion is been parsed correctly.
Best regards,
Ivan
Sent: Tuesday, September 15, 2020 10:33 AM
To: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Cc: Ivan Lucena <ivan.lucena at outlook.com>; Victoria Ponz-Sarvise <vponz-sarvise at forsk.com>
Subject: Re: [gdal-dev] ogr2ogr with ORACLE driver: limitation on table name size?
Ivan,
> https://github.com/OSGeo/gdal/blob/70a2ec1795c3e01aeaf1ac3c0f7c69a3f0fa2ca5/
> gdal/ogr/ogrsf_frmts/oci/ogrocisession.cpp#L316
The logic
if( nServerVersion >= 12 && nServerRelease >= 2 )
looks wrong to me. It will not work for 13.0 for example
Shouldn't that be
if( nServerVersion > 12 || (nServerVersion == 12 && nServerRelease >= 2) )
That said that doesn't explain issues with 12.2
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200915/a0428eb5/attachment-0001.html>
