[gdal-dev] Clip feature while query from .gdb using OpenFileGDB driver
Yang
dhyfb at foxmail.com
Wed Sep 30 01:00:51 PDT 2020
I am using OpenFileGDB driver to read .gdb data through the java binding,core codes:
Layer layer = dataSource.GetLayer("layer_name");
layer.SetSpatialFilterRect(minx,miny,maxx,maxy);
System.out.println(layer.GetFeatureCount());
layer.ResetReading();
Feature feature = layer.GetNextFeature();
while (feature != null) {
Now for a given feature I want to get the intersection geometry from the bounding box (the same as that used in the spatial filter), when using PostGIS, I can do that by
select ST_Intersect(geom,bbox) as clipped_geom from xx where geom && bbox.
So when using OpenFileGDB:
1 Can it do the intersection during the querying?
2 If not, does it mean I have to do the clip in java by myself? Does gdal provide some api?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200930/e762c9af/attachment.html>
