[gdal-dev] Failing to include libgdal.so on Fedora 32
Matthys Kroon
matthysk at gmail.com
Wed Sep 30 06:30:48 PDT 2020
Thanks for your help.
I do seem to have the file. I have libpq and libpq5 packages installed.
/usr/lib64#ls -alh libpq.so*
lrwxrwxrwx. 1 root root 13 Aug 20 14:42 libpq.so -> libpq.so.5.12
lrwxrwxrwx. 1 root root 13 Aug 20 14:42 libpq.so.5 -> libpq.so.5.12
-rwxr-xr-x. 1 root root 1.3M Aug 20 14:42 libpq.so.5.12
I think it has something to do with the postgres version. All those
references have "@RHPG_9.6" which I assume references postgres 9.6. I also
have postgres 11 and 12 installed on the system (was developing postgres
apps in my previous job). I think somehow I have a later version of libpq
installed.
I'm going to try and verify that I have the correct version installed.
On Wed, Sep 30, 2020 at 2:38 PM Andrew C Aitchison <andrew at aitchison.me.uk>
wrote:
> On Wed, 30 Sep 2020, Matthys Kroon wrote:
> > Hi,
> > I'm trying to build "sf" package in R on Fedora 32 but it fails to
> > configure gdal. The error output is below:
> > It seems to be some issue referring to a postgres lib? I have libpq-devel
> > installed.
> > I googled for hours and I'm still stuck. Please let me know what other
> > information I can provide to help troubleshoot.
> > /usr/bin/ld /usr/lib64/libgdal.so
> > ld: warning: cannot find entry symbol _start; not setting start address
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQcmdStatus at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQfname at RHPG_9.6'
> > `PQsetNoticeProcessor at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQftable at RHPG_9.6'
> On RHEL6 /usr/lib64/libpq.so.5.2 is in the package "postgresql-libs";
> on Ubuntu20.04 /usr/lib/x86_64-linux-gnu/libpq.so.5.12 is in the package
> "libpq5". The dev/devel packages have libpq.so as a symbolic link to
> these numbered .so libraries, so I guess you need a non-devel package
> like libpq or libpq5.
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQstatus at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQftablecol at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQconnectdb at RHPG_9.6'
> > `PQescapeStringConn at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `lo_close at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQputCopyEnd at RHPG_9.6
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQgetvalue at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQgetisnull at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQftype at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQfmod at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `lo_creat at RHPG_9.6'
> `PQresultStatus at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `lo_read at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQexec at RHPG_9.6'
> > `PQsetClientEncoding at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQgetlength at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQputCopyData at RHPG_9.6
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQgetResult at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `lo_write at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQfinish at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQclear at RHPG_9.6'
> `PQerrorMessage at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQnfields at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `lo_open at RHPG_9.6'
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQexecParams at RHPG_9.6
> > ld: /usr/lib64/libgdal.so: undefined reference to `PQntuples at RHPG_9.6'
> > `PQresultErrorMessage at RHPG_9.6'
> > Thanks for any help.
> > Regards,
> > Matthys
> Andrew C. Aitchison Kendal, UK
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200930/4d667071/attachment.html>
