[gdal-dev] Does OGR support GeoPackage enums in write mode (or at all?)
Andrea Aime
andrea.aime at geo-solutions.it
Tue Apr 6 05:50:34 PDT 2021
Nice! Thanks!
Cheers
Andrea
On Tue, Apr 6, 2021 at 2:43 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> as as follow-up, the mentioned below capacity is now in GDAL master per
> https://github.com/OSGeo/gdal/pull/3638
> This is implemented curretly for FileGeodatabase (reading-only, could be
> extended on the write side in the FileGDB) and GeoPackage (read/write).
> I guess this could be extended to PostgreSQL too by storing the enums in
> an auxiliary table linked through a foreign key.
> Even
> Le 15/04/2020 à 11:05, Andrea Aime a écrit :
> Hi,
> I'm trying to dump a large PostGIS database into a GeoPackage. In the
> original database some columns
> are strings, but could be more efficiently represented as enums, as they
> have a small set of values.
> GeoPackage has a native notion of enums, check the spec and search for
> "table 27" for an example:
> http://www.geopackage.org/spec/
> However I cannot find mention of them in the GPKG driver documentation:
> https://gdal.org/drivers/vector/gpkg.html
> I quickly grepped into the geopackage sources for "enum", could not find
> it in the geopackage sources.
> Also looked at the "mapFieldType" ogr2ogr parameter and at OGR SQL, did
> not find anything there either.
> So I'm wondering, is there direct support for enum fields? Any way to map
> a string column to enum during
> a ogr2ogr call?
> Best Regards,
> Andrea Aime == GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf
> Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa
> (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
> http://www.geo-solutions.it http://twitter.com/geosolutions_it
> ------------------------------------------------------- *Con riferimento
> alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
> Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
> circostanza inerente alla presente email (il suo contenuto, gli eventuali
> allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
> destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
> errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
> sarei comunque grato se potesse darmene notizia. This email is intended
> only for the person or entity to which it is addressed and may contain
> information that is privileged, confidential or otherwise protected from
> disclosure. We remind that - as provided by European Regulation 2016/679
> “GDPR” - copying, dissemination or use of this e-mail or the information
> herein by anyone other than the intended recipient is prohibited. If you
> have received this email by mistake, please notify us immediately by
> telephone or e-mail.*
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
Regards, Andrea Aime
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210406/24d96ee9/attachment-0001.html>
