[gdal-dev] Shall I continue trying to get gdal java bindings to work?
Even Rouault
even.rouault at spatialys.com
Wed Apr 7 01:25:29 PDT 2021
Paul,
you're kindly invited to help improving the documentation of
https://gdal.org/api/java.html. See the "Edit on GitHub" button on the
top right of the page to submit a contribution
Even
Le 07/04/2021 à 07:17, paul.malm at lfv.se a écrit :
> When I copy ALL the dll-files in gdal\bin (geos.dll, geos_c.dll etc.)
> to my java-jre\bin folder (where I also copied the gdalalljni.dll) it
> seems to work. Couldn’t this be added in the installation instructions
> some were?
> Kind regards,
> Paul
> *Från:*Malm, Paul (Operations AIM)
> *Skickat:* den 6 april 2021 10:42
> *Till:* 'gdal-dev at lists.osgeo.org' <gdal-dev at lists.osgeo.org>
> *Ämne:* Shall I continue trying to get gdal java bindings to work?
> Hi,
> is it possible to get Gdal java bindings to work in Windows 10? If not
> to whom do I report the error?
> I’ve downloaded release-1928-x64-gdal-3-2-1-mapserver-7-6-2.zip
> and can’t get gdalalljni.dll to load. I’ve tried to get help from here
> and from the them creating the zip –file. But without any luck.
> I just want to know if it is possible at all, since I’ve tried to get
> it to work for four weeks now.
> Has anyone at all got gdalalljni.dll to load?
> Kind regards,
> Paul
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210407/df244690/attachment.html>
