[gdal-dev] stricmp in cpl_port.h
Andrew Bell
andrew.bell.ia at gmail.com
Wed Apr 7 07:33:12 PDT 2021
Dare I suggest getting rid of EQUAL?
On Wed, Apr 7, 2021 at 10:25 AM Andrew C Aitchison <andrew at aitchison.me.uk>
wrote:
> I have developed a gdal driver plugin on Linux and am now attempting to
> build it on Windows.
> I am using the conda gdal, WIN10 SDK and the mingw-m64 clang11 compiler
> (all installed this week, latest versions I believe), but am open to
> other suggestions for building a windows gdal driver plugin.
> I get a deprecation warning from cpl_port.h when I use the EQUALS macro:
> qed.cpp:569:31: warning: 'stricmp' is deprecated: The POSIX name for this
> item is deprecated. Instead, use the ISO C and
> C++ conformant name: _stricmp. See online help for details.
> [-Wdeprecated-declarations]
> if( magic == qed_magic &&
> EQUAL(CPLGetExtension(poOpenInfo->pszFilename),"qed")) {
> C:\ProgramData\Miniconda3\Library\include/cpl_port.h:576:36: note:
> expanded from macro 'EQUAL'
> # define EQUAL(a,b) (STRCASECMP(a,b)==0)
> C:\ProgramData\Miniconda3\Library\include/cpl_port.h:565:38: note:
> expanded from macro 'STRCASECMP'
> # define STRCASECMP(a,b) (stricmp(a,b))
> C:\Program Files (x86)\Windows
> Kits\10\Include\10.0.19041.0\ucrt\string.h:544:20: note: 'stricmp' has
> been explicitly
> marked deprecated here
> _Check_return_ _CRT_NONSTDC_DEPRECATE(_stricmp)
> Kits\10\Include\10.0.19041.0\ucrt\corecrt.h:414:50: note: expanded from
> macro
> '_CRT_NONSTDC_DEPRECATE'
> #define _CRT_NONSTDC_DEPRECATE(_NewName) _CRT_DEPRECATE_TEXT(
> C:\Program Files (x86)\Microsoft Visual
> Studio\2019\Community\VC\Tools\MSVC\14.28.29910\include\vcruntime.h:310:47:
> note:
> expanded from macro '_CRT_DEPRECATE_TEXT'
> #define _CRT_DEPRECATE_TEXT(_Text) __declspec(deprecated(_Text))
> 1 warning generated.
> Should cpl_port be updated to use _stricmp or is there a better
> alternative (I wondered about strcasecmp but don't see it) ?
> I see that
> frmts/mrsid_lidar/makefile.vc
> sets
> EXTRAFLAGS = $(MRSID_INCLUDE) -D_CRT_SECURE_NO_WARNINGS
> /Zc:wchar_t-
> but I would rather not turn off warnings, since my code is clean enough to
> use -Wall -Wextra -Weverything on linux.
> Thanks.
> Andrew C. Aitchison Kendal, UK
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210407/30ce3b93/attachment.html>
