[gdal-dev] Merging TIFF files creates offset / deformation
Hotmail
rlelamer at hotmail.fr
Thu Apr 8 03:39:55 PDT 2021
I have a PNG library (524288 tiles of 256px * 256px) which I georeferenced via GDAL.
# This first part works correctly.
• ullr:
> ulx = (360 * (column / 1024)) - 180
> uly = 90 - (180 * (line / 512))
> lrx = ulx + 0.3515625
> lry = uly - 0.3515625
> ULLR = ulx + '' + uly + '' + lrx + '' + lry
> gdal_translate -of VRT -a_srs EPSG:4326 -co NBITS=1 Path/Of/Input.png Path/Of/Output.vrt -a_ullr + ULLR
> gdalwarp -s_srs EPSG:4326 -t_srs EPSG:3857 -co NBITS=1 Path/Of/Input.vrt Path/Of/Output.tiff
# The second part works correctly too
I merge the tiles of a row (1024 TIFF tiles) using a VRT then from it I create the TIFF file
> #!/bin/bash
> for i in `seq 0 1 511`;
> do
> gdalbuildvrt Path/Of/lines_vrt/map_$i.vrt Path/Of/tiff/map_11_*_$i.tiff
> gdal_translate -co NBITS=1 Path/Of/lines_vrt/map_$i.vrt Path/Of/lines_tiff/map_$i.tiff
> done
Here if I use gdal_merge.py, either I get an invalid file (1.xMo while the lines are approx 60Mo) or I observe a offset / deformation ... (In QGIS)
# The last part doesn't work properly (and I don't know why ...)
Here I am merging all the lines (TIFF files) into a global TIFF file using the same method as before. (with a list.txt file)
> #!/bin/bash
> gdalbuildvrt -input_file_list Path/Of/lines_tiff/list.txt Path/Of/global_vrt/map_global.vrt
> gdal_translate -co NBITS=1 Path/Of/global_vrt/map_global.vrt Path/Of/map_global.tiff
and I observe a offset / deformation. (In QGIS again)
I wonder what am I doing that is wrong
My final goal is to use the global file (TIFF) with gdal2tiles.py (Tiles overlay on GMaps / OSM)
Thanks
