[gdal-dev] C# bindings compilation
Paul Harwood
runette at gmail.com
Mon Apr 12 00:59:44 PDT 2021
Thanks Even
On Sun, 11 Apr 2021 at 19:17, Even Rouault <even.rouault at spatialys.com>
wrote:
> Paul,
> RFCs are only required for substantial changes that affect the OSGeo/GDAL
> repository. People who contribute to Conda Forge are free to do so
> (hopefully in good faith, that is not defacing too much the GDAL "brand").
> If we decided to retire the C# bindings from OSGeo/GDAL this should
> probably go through some motion
Cool. I will do that then.
I would prefer if the result is at least semi-official and to have some
other people from the community listed as maintainers/owners on the package
in case something happens to me. There are too many zombie packages out
there already!
Would that be you?
> Regarding build issues on Linux, I could reproduce that, but was like
> "worked half time". I finally realized that you had to run "make" twice
> because of oddities in the Makefile dependency rules. And there was the
> base swig/SWIGmake.base file generating .cpp files in swig/csharp whereas
> swig/csharp/GNUmakefile generated them in swig/csharp/gdal|const|ogr|osr.
> I've hopefully addressed and rationalized that in
> https://github.com/OSGeo/gdal/pull/3670. At least now on my local machine
> (ubuntu 20.04), one a clean swig/csharp, "cd swig/csharp && make && make
> test" works. The error you got was similar to the one I got
It is good to able to see that it works and a working example. I will work
with what you have in 3670
> Regarding your compilation issues with your current recipee, I'd expect
> you to have to rather copy most of the content of swig/include,
> swig/include/csharp and swig/csharp in your own repository and adapt them
> to a standalone build where you include and link against an installed
> prefix of the native libgdal.
That is sort of where I am heading. I want to avoid having anything
between the conda feedstock and the root GDAL repo (unless and until there
is any change to the way that the GDAL project manages bindings) for
maintenance reasons and to avoid creating more zombies. I.e. there is only
one definition of the SWIG objects but I have my own makefiles.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210412/6c23e40b/attachment.html>
