[gdal-dev] COG + javascript + openlayers
Javier Jimenez Shaw
j1 at jimenezshaw.com
Tue Apr 13 01:31:00 PDT 2021
Maybe this channel is not the best place for this question. Do you know a
better place to ask?
Thank you
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Tue, 6 Apr 2021 at 22:40, Javier Jimenez Shaw <j1 at jimenezshaw.com> wrote:
> Hi
> While I was reading about COG format, I thought it was great to replace
> "gdal2tiles" if the COG was properly generated (I mean, using the option
> TILING_SCHEME=GoogleMapsCompatible , and maybe something else I miss. I am
> generating it, so I can optimize that).
> Then I was expecting that geotiff.js (or any other client js library) will
> be able to do the proper RANGE request to produce the tiling that libraries
> like openlayers of leaflet is expecting. Yes, in Web Mercator projection
> with aligned tiles, so no transformation is needed.
> My initial target is just for RGBA uint8 images... plain vanilla. Storing
> the COG file in S3, without any proxy in between doing any conversion. Just
> relying on the RANGE request to get the needed area. My initial idea is to
> keep the openlayers/leaflet 256x256 tiles. This allows parallel requests to
> the server, and is very fast (and I do not have to refactor all my js
> code). But maybe there is a better/faster solution (again, with S3 direct
> access, no proxy in the server side. That would require deploying the
> "proxy" on every geographical region).
> However I have not found any proper solution (my search-fu is not the
> best, to be honest). I would like something that performs *at least* as
> fast as the tiles produced by gdal2tiles.
> Do you know any solution/example?
> Thanks
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210413/f4dd09de/attachment.html>
