[gdal-dev] Gdal.Open on S3 using IAM roles
Jeannie May jeannie_may at trimble.com
Thu Apr 15 15:10:09 PDT 2021
  I'll try to get to this this afternoon. What gdalinfo commands would be
best to reveal the issue?
On Thu, Apr 15, 2021 at 9:28 AM Patrick Young <
patrick.mckendree.young at gmail.com> wrote:
> AWS_REGION shouldn't cause problems.
> If it was me, I'd just hop onto the box and test by running gdalinfo
> /vsis3/... with verbose curl config options set and so on and make sure I
> could get that working as a sanity check.
> On Wed, Apr 14, 2021 at 3:21 PM Jeannie May <jeannie_may at trimble.com>
> wrote:
>> This is the gdal setup. None of the AWS keys are set excep region (could
>> that be an issue). Where would I expect to see the logging - none is
>> showing up in our logs. Do we need to configure the output to our log?
>>     public GdalClient(IConfigurationStore configStore, ILoggerFactory
>> loggerFactory)
>>       _log = loggerFactory.CreateLogger<GdalClient>();
>>       GdalBase.ConfigureAll();
>>       Gdal.AllRegister();
>>       //For debugging s3 access problems
>>       Gdal.SetConfigOption("CPL_CURL_VERBOSE", "YES");
>>       Gdal.SetConfigOption("CPL_DEBUG", "YES");
>>       Gdal.SetConfigOption("AWS_REGION", "us-west-2");
>>       _log.LogDebug($"#{nameof(GdalClient)} AWS_PROFILE: {
>> Gdal.GetConfigOption("AWS_PROFILE", "NotFound")} " +
>>                     $"AWS_ACCESS_KEY_ID: {
>> Gdal.GetConfigOption("AWS_ACCESS_KEY_ID", "NotFound")} " +
>>                     $"AWS_SECRET_ACCESS_KEY: {
>> Gdal.GetConfigOption("AWS_SECRET_ACCESS_KEY", "NotFound")} " +
>>                     $"AWS_SESSION_TOKEN: {
>> Gdal.GetConfigOption("AWS_SESSION_TOKEN", "NotFound")} " +
>>                     $"AWS_NO_SIGN_REQUEST: {
>> Gdal.GetConfigOption("AWS_NO_SIGN_REQUEST", "NotFound")} " +
>>                     $"AWS_DEFAULT_PROFILE: {
>> Gdal.GetConfigOption("AWS_DEFAULT_PROFILE", "NotFound")} ");
>>       _awsBucketName =
>> configStore.GetValueString("AWS_DESIGNIMPORT_BUCKET_NAME");
>> and this is the open which times out:
>>  public string GetMetadata(string fileName, bool s3=true)
>>       var path = s3 ? $"/vsis3/{_awsBucketName}/{fileName}" : fileName;
>>       var dataset = Gdal.Open(path, Access.GA_ReadOnly);
>> On Thu, Apr 15, 2021 at 9:11 AM Patrick Young <
>>> That should be the behavior, and I use it all the time so I am confident
>>> it works...
>>> Is it possible you have set any of the AWS_* variables in your
>>> EC2/container environment? I think that could spoil it for you.
>>> You can set CPL_CURL_VERBOSE to YES and get an idea of the network
>>> requests GDAL is doing.   If things are just slow, you might need to set GDAL_DISABLE_READDIR_ON_OPEN=YES
>>> and CPL_VSIL_CURL_ALLOWED_EXTENSIONS=tif  as described here:
>>> https://trac.osgeo.org/gdal/wiki/CloudOptimizedGeoTIFF
>>> On Wed, Apr 14, 2021 at 3:01 PM Jeannie May <jeannie_may at trimble.com>
>>> wrote:
>>>> Further to this discussion, I guess we had hoped that GDal would pick
>>>> up the EC2 instance profile credentials as the s3Client upload does as per:
>>>> https://gdal.org/user/virtual_file_systems.html#vsis3
>>>>     5. If none of the above method succeeds, instance profile
>>>> credentials will be retrieved when GDAL is used on EC2 instances.
>>>> On Thu, Apr 15, 2021 at 8:58 AM Jeannie May <jeannie_may at trimble.com>
>>>> wrote:
>>>>> Thank you Patrick for your prompt reply.
>>>>> Our app runs on an EC2 instance and has no user context. It uses the
>>>>> s3Client SDK upload, utilizing the existing IAM role/policy already setup.
>>>>> Are you saying here that I need to as a 1-time process generate a
>>>>> secret and access key for our existing policy/role, store it in environment
>>>>> variables (AWS_SECRET_ACCESS_KEY and AWS_ACCESS_KEY_ID only?) and the
>>>>> gdal SDK will use that?
>>>>> Jeannie May
>>>>> Jeannie M
>>>>> Tue, Apr 13, 2:44 PM (2 days ago)
>>>>> Reply
>>>>> to gdal-dev
>>>>> I'm new to using Gdal. How do I configure gdal to use an IAM role,
>>>>> rather than defining an aws-Profile?
>>>>> I get a timeout doing a gdal.Open() on a tiff file on S3 using vsis3,
>>>>> while trying to use an IAM role.
>>>>> I'm using MaxRev.Gdal.Core 3.2.0.250. Netcore 3.1 c#, running in a
>>>>> Linux container.
>>>>> Note that defining an AWS_Profile etc works ok, but I need to use IAM
>>>>> roles. Prior to trying to open the file with gdal, I successfully upload
>>>>> using s3Client (which uses the IAM role), so it's something specific to the
>>>>> Gdal.Open().
>>>>> using GetConfigOption() I can see that none of the following are set
>>>>> AWS_PROFILE; AWS_ACCESS_KEY_ID; AWS_SECRET_ACCESS_KEY; AWS_SESSION_TOKEN;
>>>>> AWS_NO_SIGN_REQUEST; AWS_DEFAULT_PROFILE
>>>>> *Jeannie May*
>>>>> Senior Software Engineer
>>>>> 11 Birmingham Drive, Christchurch | 963 5305 Office
>>>>> www.trimble.com
>>>>> Connect with us!
>>>>> Patrick Young <patrick.mckendree.young at gmail.com>
>>>>> Wed, Apr 14, 3:47 AM (1 day ago)
>>>>> Reply
>>>>> to me, gdal
>>>>> See
>>>>> https://aws.amazon.com/premiumsupport/knowledge-center/iam-assume-role-cli/ ,
>>>>> they describe how to assume a role and set the usual AWS_*
>>>>> environment variables that GDAL should pick up.
>>>>> There's discussion on vsis3 related stuff (e.g. authentication) here:
>>>>> P
>>>> *Jeannie May*
>>>> www.trimble.com
>>>> Connect with us!
>> *Jeannie May*
>> www.trimble.com
>> Connect with us!
*Jeannie May*
www.trimble.com
Connect with us!
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210416/cab67cb2/attachment-0001.html>
