[gdal-dev] WCS server error. Coverage not found
Elena Ruiz
eruiz at aplitop.com
Tue Apr 20 07:50:47 PDT 2021
Hello I am testing the WCS service but I have a error that I don’t understand.
If I put in a web server this:
http://www.juntadeandalucia.es/medioambiente/mapwms/REDIAM_WCS_mdt?SERVICE=WCS&VERSION=1.0.0&REQUEST=GetCoverage&COVERAGE= Modelo%20Digital%20de%20Elevaciones%20(MDE)%20de%20Andalucia%2010%20m&CRS=EPSG:25830&FORMAT=GTiff&BBOX=531006.299122,4100120.659408,544263.630224,4112381.66471&WIDTH=1325&HEIGHT=1226&OUTPUTCRS=C:\Users\elena\AppData\Local\Temp\imagen.tif
this works ok and download a TIFF image.
But if I try to do this in gdal:
>gdal_translate -oo CACHE=wcs_cache -oo CLEAR_CACHE -oo INTERLEAVE=PIXEL -projwin 531006.299122 4100120.659408 544263.630224 4112381.66471 -outsize 1325 1226 "WCS:http://www.juntadeandalucia.es/medioambiente/mapwms/REDIAM_WCS_mdt?VERSION=1.0.0&COVERAGE=Modelo%20Digital%20de%20Elevaciones%20(MDE)%20de%20Andalucia%2010%20m" "C:\Users\elena\AppData\Local\Temp\imagen.tif"
The result is:
ERROR 1: msWCSGetCoverage(): WCS server error. COVERAGE=Modelo%20Digital%20de%20Elevaciones%20(MDE)%20de%20Andalucia%2010%20m not found, not in supported layer list. A layer might be disabled for this request. Check wcs/ows_enable_request settings.
I have tried with other version of service WCS, version 1.1.2 and 2.0.1, the difference is the name of layer, in this cases is “mdt_10”, but the result in gdal is the same.
>gdalinfo "WCS:https://www.juntadeandalucia.es/medioambiente/mapwms/REDIAM_WCS_mdt?version=2.0.1"
Driver: WCS/OGC Web Coverage Service
Files: C:\Users\elena\.gdal\wcs_cache\Zatax.aux.xml
Size is 512, 512
Origin = (0.000000000000000,0.000000000000000)
Pixel Size = (1.000000000000000,1.000000000000000)
Metadata:
WCS_GLOBAL#crsSupported=http://www.opengis.net/def/crs/EPSG/0/3042,EPSG:3042
WCS_GLOBAL#formatSupported=image/png,image/jpeg
WCS_GLOBAL#InterpolationSupported=NEAREST,AVERAGE,BILINEAR
WCS_GLOBAL#Keywords=WCS,MDT
WCS_GLOBAL#Profiles=WCS/2.0/conf/core,WCS_protocol-binding_get-kvp/1.0/conf/get-kvp,WCS_protocol-binding_post-xml/1.0/conf/post-xml,GMLCOV/1.0/conf/gml-coverage,GMLCOV/1.0/conf/multipart,GMLCOV/1.0/conf/special-format,GMLCOV_geotiff-coverages/1.0/conf/geotiff-coverage,WCS_service-extension_crs/1.0/conf/crs,WCS_service-extension_scaling/1.0/conf/scaling,WCS_service-extension_range-subsetting/1.0/conf/record-subsetting,WCS_service-extension_interpolation/1.0/conf/interpolation
WCS_GLOBAL#ServiceIdentification.Abstract=Nodo de la Red de Informacion Ambiental de Andalucia. Junta de Andalucia. Servicio WCS del Modelo Digital de Elevaciones (MDE) de Andalucia de 10 m de resolucion generado a partir de los vuelos realizados en 2010 (cuadrantes Sureste (SE) Suroeste (SW)) y 2011 (cuadrantes Noreste (NE) y Noroeste (NW)). Tambien se muestra el Modelo Digital de Elevaciones de Andalucia de 100 m generado a partir de MDE por cuadrantes (resolucion 10x10 y 5x5m) remuestreados procedentes de los proyectos de produccion de Ortofotos regionales de Andalucia y del PNOA. Integrado en la Infraestructura de Datos Espaciales de Andalucia, siguiendo las directrices del Sistema Cartografico de Andalucia.
WCS_GLOBAL#ServiceIdentification.AccessConstraints=Este servicio se puede usar de modo libre y gratuito siempre que se mencione a los autores y propietarios de la informacion
WCS_GLOBAL#ServiceIdentification.Fees=Gratuito
WCS_GLOBAL#ServiceIdentification.Title=REDIAM. WCS Modelo Digital de Elevaciones (MDE) de Andalucia
WCS_GLOBAL#ServiceProvider.ProviderName=Consejería de Agricultura, Ganadería, Pesca y Desarrollo Sostenible. Junta de Andalucía
WCS_GLOBAL#ServiceProvider.ProviderSite=https://www.juntadeandalucia.es/medioambiente/mapwms/REDIAM_WCS_mdt
WCS_GLOBAL#ServiceProvider.ServiceContact.ContactInfo.Address.AdministrativeArea=Sevilla
WCS_GLOBAL#ServiceProvider.ServiceContact.ContactInfo.Address.City=Sevilla
WCS_GLOBAL#ServiceProvider.ServiceContact.ContactInfo.Address.Country=Spain
WCS_GLOBAL#ServiceProvider.ServiceContact.ContactInfo.Address.DeliveryPoint=Avda. Manuel Siurot,50
WCS_GLOBAL#ServiceProvider.ServiceContact.ContactInfo.Address.PostalCode=41071
WCS_GLOBAL#ServiceProvider.ServiceContact.ContactInfo.ContactInstructions=--
WCS_GLOBAL#ServiceProvider.ServiceContact.ContactInfo.HoursOfService=--
WCS_GLOBAL#ServiceProvider.ServiceContact.ContactInfo.Phone.Facsimile=--
WCS_GLOBAL#ServiceProvider.ServiceContact.ContactInfo.Phone.Voice=+34955003400
WCS_GLOBAL#ServiceProvider.ServiceContact.IndividualName=--
WCS_GLOBAL#ServiceProvider.ServiceContact.PositionName=Servicio de Informacion y Analisis Ambiental
WCS_GLOBAL#ServiceProvider.ServiceContact.Role=--
WCS_GLOBAL#version=2.0.1
Subdatasets:
SUBDATASET_1_NAME=WCS:https://www.juntadeandalucia.es/medioambiente/mapwms/REDIAM_WCS_mdt?version=2.0.1&coverage=mdt_10
SUBDATASET_1_DESC=mdt_10
SUBDATASET_2_NAME=WCS:https://www.juntadeandalucia.es/medioambiente/mapwms/REDIAM_WCS_mdt?version=2.0.1&coverage=mdt_100
SUBDATASET_2_DESC=mdt_100
Corner Coordinates:
Upper Left ( 0.0000000, 0.0000000)
Lower Left ( 0.000, 512.000)
Upper Right ( 512.000, 0.000)
Lower Right ( 512.000, 512.000)
Center ( 256.000, 256.000)
>gdalinfo "WCS:https://www.juntadeandalucia.es/medioambiente/mapwms/REDIAM_WCS_mdt?version=2.0.1&coverage=mdt_10"
ERROR 1: HTTP error code : 404
ERROR 1: NoSuchCoverage: msWCSGetCoverage20(): WCS server error. COVERAGEID=mdt_10 not found, not in supported layer list. A layer might be disabled for this request. Check wcs/ows_enable_request settings.
gdalinfo failed - unable to open 'WCS:https://www.juntadeandalucia.es/medioambiente/mapwms/REDIAM_WCS_mdt?version=2.0.1&coverage=mdt_10'.
Can anyone help me? Thank you very much and regards
[https://www.aplitop.com/descargas/firma1.jpg]
Elena Ruiz
Sofware Development & Technical Support
Tel. +34 952 43 97 71
Sumatra, 9 - 29190 Malaga (Spain)
www.aplitop.com
[cid:SocialLink_Facebook_32x32_a745adb8-c250-4372-8480-e77f503dad3d.png]<https://www.facebook.com/AplitopSL/> [cid:SocialLink_Twitter_32x32_858247f6-9d4a-4740-a6b3-9b5ebfd98a97.png] <https://twitter.com/aplitop> [cid:SocialLink_Linkedin_32x32_154d63de-bf68-468f-9eb0-ffed102fac77.png] <https://www.linkedin.com/company/aplitop> [cid:SocialLink_Youtube_32x32_0dea15dd-3774-4086-be9d-f62560b70c86.png] <https://www.youtube.com/user/aplitop>
In accordance with the provisions of the European Regulation of Data Protection 2016/679 (Reglamento Europeo de Proteccion de Datos 2016/679), we inform you that the data and the information you provide us through this medium will be used by APLITOP, S.L., with C.I.F. B-92543396 and with address at C / Sumatra, 9, Malaga, 29190, in order to answer your questions and inform you about our products. The data provided will be kept as long as it does not request its cessation and will not be transferred to third parties except in cases where there is a legal obligation. You have the right to access your personal data, correct inaccurate data or request its deletion when the data is no longer necessary for the purposes that were collected, as well as any rights recognized in the RGPD 2016/679
<https://www.aplitop.com/Event/en/358/intergeo-2019>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210420/6cf8e4ba/attachment-0001.html>
Type: image/png
Desc: SocialLink_Facebook_32x32_a745adb8-c250-4372-8480-e77f503dad3d.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210420/6cf8e4ba/attachment-0004.png>
Type: image/png
Desc: SocialLink_Twitter_32x32_858247f6-9d4a-4740-a6b3-9b5ebfd98a97.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210420/6cf8e4ba/attachment-0005.png>
Type: image/png
Desc: SocialLink_Linkedin_32x32_154d63de-bf68-468f-9eb0-ffed102fac77.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210420/6cf8e4ba/attachment-0006.png>
Type: image/png
Desc: SocialLink_Youtube_32x32_0dea15dd-3774-4086-be9d-f62560b70c86.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210420/6cf8e4ba/attachment-0007.png>
