[gdal-dev] Python create BigTIFF image
Javier Jimenez Shaw
j1 at jimenezshaw.com
Tue Apr 20 12:41:44 PDT 2021
I don't think so. Bigtiff is a creation option, that defines the format of
the file.
ni hao <ni_hao88 at hotmail.com> schrieb am Di., 20. Apr. 2021, 21:37:
> Even,
> Thank you for your reply.
> You are right: ds = gdal.GetDriverByName('GTiff').Create( ) is under 4GB.
> It was the next command pushes GTiff over 4GB:
> ds.BuildOverviews('AVERAGE_MAGPHASE', [2,4,8,16])
> Is there a way to specify BIGTIFF in ds.BuildOverviews() ?
> *From:* Even Rouault <even.rouault at spatialys.com>
> *Sent:* April 20, 2021 3:56 PM
> *To:* ni hao <ni_hao88 at hotmail.com>; gdal-dev at lists.osgeo.org <
> gdal-dev at lists.osgeo.org>
> *Subject:* Re: [gdal-dev] Python create BigTIFF image
> Le 20/04/2021 à 20:53, ni hao a écrit :
> Hi list,
> I use Python to create GeoTiff image, and I get the error because it
> exceeds 4GB.
> ds = gdal.GetDriverByName('GTiff').Create(output_magnitude, xsize, ysize,
> 1, gdal.GDT_Float32)
> ERROR 1: TIFFReadDirectory:Failed to read directory at offset 4294957836
> ERROR 1: TIFFWriteDirectoryTagData:Maximum TIFF file size exceeded. Use
> BIGTIFF=YES creation option.
> I need to turn on *BIGTIFF=YES*
> https://gdal.org/drivers/raster/gtiff.html
> But I don't do know how. I tried:
> 1, gdal.GDT_Float32, BIGTIFF=YES)
> 1, gdal.GDT_Float32, options=['BIGTIFF=YES'])
> But as you didn't specify compression, it should have done that
> automatically. Can you indicate the exact values of xsize and ysize you use
> but it didn't work.
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210420/1f38bb39/attachment.html>
