[gdal-dev] Python create BigTIFF image
ni hao
ni_hao88 at hotmail.com
Tue Apr 20 13:10:01 PDT 2021
Thank you Even and Javier for your help.
GDAL list is great!!
Sent: April 20, 2021 5:03 PM
To: ni hao <ni_hao88 at hotmail.com>; gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] Python create BigTIFF image
Ah ok that explains it then. The heuristics in the Create() method only takes into account the full resolution image, not potential overviews you might add. So you have to go with the explict option = ['BIGTIFF=YES'] argument I suggested
Le 20/04/2021 à 21:37, ni hao a écrit :
Even,
Thank you for your reply.
You are right: ds = gdal.GetDriverByName('GTiff').Create( ) is under 4GB.
It was the next command pushes GTiff over 4GB:
ds.BuildOverviews('AVERAGE_MAGPHASE', [2,4,8,16])
Is there a way to specify BIGTIFF in ds.BuildOverviews() ?
From: Even Rouault <even.rouault at spatialys.com><mailto:even.rouault at spatialys.com>
Sent: April 20, 2021 3:56 PM
To: ni hao <ni_hao88 at hotmail.com><mailto:ni_hao88 at hotmail.com>; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org> <gdal-dev at lists.osgeo.org><mailto:gdal-dev at lists.osgeo.org>
Le 20/04/2021 à 20:53, ni hao a écrit :
Hi list,
I use Python to create GeoTiff image, and I get the error because it exceeds 4GB.
ds = gdal.GetDriverByName('GTiff').Create(output_magnitude, xsize, ysize, 1, gdal.GDT_Float32)
ERROR 1: TIFFReadDirectory:Failed to read directory at offset 4294957836
ERROR 1: TIFFWriteDirectoryTagData:Maximum TIFF file size exceeded. Use BIGTIFF=YES creation option.
I need to turn on BIGTIFF=YES
https://gdal.org/drivers/raster/gtiff.html
But I don't do know how. I tried:
ds = gdal.GetDriverByName('GTiff').Create(output_magnitude, xsize, ysize, 1, gdal.GDT_Float32, BIGTIFF=YES)
ds = gdal.GetDriverByName('GTiff').Create(output_magnitude, xsize, ysize, 1, gdal.GDT_Float32, options=['BIGTIFF=YES'])
But as you didn't specify compression, it should have done that automatically. Can you indicate the exact values of xsize and ysize you use ?
but it didn't work.
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210420/bf4457b5/attachment.html>
