[gdal-dev] Modify original ColorTable in VRT & TIFF files
lars.schylberg at blixtmail.se
Thu Apr 22 13:44:05 PDT 2021
I had to deal a lot with palette tiff images a couple of years ago.
What I did was that edited the vrt files with sed inline editing:
Some examples:
Insert a text file after the row that is: /VRTRasterBand dataType="Byte" band="1" The inserted file here is orig_colortable_vrt.txt:
sed -i -e '/VRTRasterBand dataType="Byte" band="1"/r orig_colortable_vrt.txt' image_6.vrt
Remove a certain line that contains "NoDataValue"
sed -i -e '/NoDataValue/d' image_6.vrt
There a also a sed commands to delete certain rows. Just read many sed examples.
Have fun / Lars Schylberg
22 april 2021 kl. 20:25, "Hotmail" <rlelamer at hotmail.fr> skrev:
> Hi all,
> I'm looking to modify the original ColorTable, when georeferencing, PNG => gdal_translate +
> gdalwarp => TIFF.
>> gdal_translate -of VRT -a_srs EPSG:4326 file_png file_vrt -a_ullr xxxx
>> gdalwarp -s_srs EPSG:4326 -t_srs EPSG:3857 file_vrt file_tiff
> If I open the VRT file and do the edit manually, the output TIFF file is correct.
> The problem is that I have 524288 files ... so I would like to do the modification automatically,
> via gdal_translate.
> But I don't quite understand using the parameters of the command ...
> • Original VRT & TIFF files
> # VRT
> <VRTRasterBand dataType="Byte" band="1">
> <ColorInterp>Palette</ColorInterp>
> <ColorTable>
> <Entry c1="0" c2="0" c3="255" c4="255" />
> <Entry c1="255" c2="255" c3="255" c4="255" />
> <Entry c1="0" c2="0" c3="0" c4="255" />
> </ColorTable>
> </VRTRasterBand>
> # TIFF
> Band 1 Block=63153x1 Type=Byte, ColorInterp=Palette
> Color Table (RGB with 256 entries)
> 0: 0,0,0,255
> 1: 255,255,255,255
> 2: 0,0,0,255
> 255: 0,0,0,255
> I want this :
> • Modified VRT and TIFF files
> # VRT
> <ColorTable>
> <Entry c1="0" c2="255" c3="0" c4="255" />
> <Entry c1="255" c2="0" c3="0" c4="255" />
> </ColorTable>
> </VRTRasterBand>
> # TIFF
> 0: 0,0,255,255
> 1: 0,255,0,255
> 2: 255,0,0,255
> 255: 255,0,0,255
> Whatever I find, redirects me to gdaldem (which I can't use). In gdal_translate, it seems to me
> that the parameter -colorinterp_X might be suitable
> but I can't find any concrete examples (or I have not looked in the right place).
> I want to impose the following parameters:
> Band 1
> Type = Byte
> ColorInterp = Palette
> In ColorTable:
> Entry 0 = 0,0,255,255
> Entry 1 = 0,255,0,255
> Entries 2 to 255 = 255,0,0,255
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
