[gdal-dev] how to use tiledb datasets on gcs?
Even Rouault
even.rouault at spatialys.com
Fri Apr 23 07:20:07 PDT 2021
Sean,
my understanding of the commit is that internally the tiledb SDK handles
cloud storage by itself (ie not relying on GDAL virtual file systems)
and using s3:// / gcs:// naming conventions, and the purpose of the
below referenced commit is, for the GDALOpen() code path, to remap
/vsis3/ to s3:// , since that's what tiledb SDK expects. But Norman
might better comment on.
Even
Le 23/04/2021 à 16:14, Sean Gillies a écrit :
> Hi Vincent, Even.
> Why would we do this when /vsigcs/... should work? Letting individual
> drivers set their own conventions for dataset names seems, to me, to
> hurt long-term maintenance and interoperability.
> On Fri, Apr 23, 2021 at 7:34 AM Vincent Schut <schut at satelligence.com
> <mailto:schut at satelligence.com>> wrote:
> Thanks for confirming, Even. That doesn't look too difficult. I'll
> give it a try.
> On 4/23/21 3:09 PM, Even Rouault wrote:
>> I guess you should add something similar to
>> https://github.com/OSGeo/gdal/commit/3623f9c91a2c513af204d30fe25314dbe5c7b9be
>> <https://github.com/OSGeo/gdal/commit/3623f9c91a2c513af204d30fe25314dbe5c7b9be>
>> for /vsigs
>> Le 23/04/2021 à 14:59, Vincent Schut a écrit :
>>> On 4/23/21 2:17 PM, Vincent Schut wrote:
>>>> Hi, how should I specify a tiledb dataset's url that resides on
>>>> gcs (google cloud storage) to gdal? I've tried several
>>>> combinations of gcs://, /vsigs/, prefixed with TILEDB:// or
>>>> not, but no luck. I've looked in the driver source, and
>>>> apparently there is only a /vsis3/ -> tiledb uri translation,
>>>> but no equivalent gcs one?
>>> To clarify this a bit: writing works:
>>> gdal_translate -of tiledb -co COMPRESSION=ZSTD
>>> S2B_MSIL1C_20210227T032659_N0209_R018_T47MQV_20210227T072433.tif
>>> gcs://s11-dev-vincent-tiledb-test-public/S2B_MSIL1C_20210227T032659_N0209_R018_T47MQV_20210227T072433.tiledb
>>> and the file is correctly created in the bucket. However, when I
>>> want to open it, it fails:
>>> gdalinfo -if tiledb
>>> ERROR 4:
>>> gcs://s11-dev-vincent-tiledb-test-public/S2B_MSIL1C_20210227T032659_N0209_R018_T47MQV_20210227T072433.tiledb:
>>> No such file or directory
>>> gdalinfo failed - unable to open
>>> 'gcs://s11-dev-vincent-tiledb-test-public/S2B_MSIL1C_20210227T032659_N0209_R018_T47MQV_20210227T072433.tiledb'.
>>> Is there any way to correctly specify this tiledb url on gcs for
>>> gdal?
>>> Vincent.
> Sean Gillies
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210423/1f06fece/attachment-0001.html>
