[gdal-dev] GDAL question
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Fri Apr 23 07:21:09 PDT 2021
You can't update with ogr2ogr. Use ogrinfo instead. I believe that you will
find good examples from gis.stackexchange
https://gis.stackexchange.com/search?q=ogrinfo+update
-Jukka Rahkonen-
Peter P wrote
> It is works, Thanks
> Now I trying update row.
> In SQL will be: /UPDATE "table1" SET "TestGeometry"=.... WHERE "Name" =
> 'testname'/
> How is this possible in ogr2ogr? I use -update, -append not work...
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
