[gdal-dev] GDAL 3.3.0beta1 available
Greg Troxel
gdt at lexort.com
Sat Apr 24 07:39:00 PDT 2021
Even Rouault <even.rouault at spatialys.com> writes:
> - http://download.osgeo.org/gdal/3.3.0/gdal-3.3.0beta1.tar.gz
The tl;dr is:
- I'm seeing bad transforms NAD83/ITRF with 3.3.0beta1 but I do not
have any basis to blame 3.3.0 because a lot of other things are in
flux.
- If you are using 3.3.0beta1 and transforms I suggest looking at your
output data.
I have noticed a problem but I have little idea where it is. I will be
looking into it myself but I wanted to mention it so that others could
be on the lookout.
Besides updating to gdal, I'm doing a general software freshening and
rebuilding lots of things, but aside from the gdal beta my geo packages
haven't changed versions. I have proj 6.3.2 with installed grids, which
was just rebuilt.
The background is that I'm mostly working in EPSG:6319 which is
NAD83(2011).
I transform to EPSG:7912 which is ITRF2014 to display the data on
leaflet webmaps (as a proxy for WGS84 to avoid null transforms).
I noticed that my points on the webmap were very far off, displaced very
roughly 35m ESE. I then put an NAD83 version in the webspace, and that
made things look ok (with the ~1 meter error from treating NAD83 and
ITRF2014 as equal, surely).
I'm extracting things from a geopackage in 6319 like
ogr2ogr -f GeoJSON -t_srs "EPSG:7912" -s_srs "EPSG:6319" FOO/issues.geojson foo.gpkg issues
ogr2ogr -f GeoJSON -t_srs "EPSG:6319" -s_srs "EPSG:6319" FOO/issues-nad83.geojson foo.gpkg issues
which has previously been fine. I'm definitely getting very large
offsets from two files extracted seconds apart from the very same
geopackage.
So this is not a request for help, but if you are using ogr2ogr to
transform datums, and you are using gdal 3.3.0beta1 especially with proj
6, I'd suggest a quick look at your output data to see if it seems ok.
I will be retesting after all the software rebuilds are done, and
rolling back to released gdal. (Yes, I know proj 6.3 is old and that I
should update.)
Thanks,
Greg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210424/a348e74d/attachment-0001.sig>
