[gdal-dev] GetAxesCount returns a wrong value
Javier Jimenez Shaw
j1 at jimenezshaw.com
Mon Apr 26 12:03:45 PDT 2021
If I try to get the number of axes in C++ from the srs "EPSG:29901+5773", I
get different values depending on how I create the wkt.
I am using the method "OGRSpatialReference::GetAxesCount()"
If I create it with projinfo with the option "--boundcrs-to-wgs84", the
number of axis is 0.
and the error message twice
ERROR 1: PROJ: proj_crs_get_coordinate_system: Object is not a SingleCRS
projinfo EPSG:29901+5773 -o WKT1:GDAL --boundcrs-to-wgs84
WKT1:GDAL string:
COMPD_CS["OSNI 1952 / Irish National Grid + EGM96 height",
PROJCS["OSNI 1952 / Irish National Grid",
GEOGCS["OSNI 1952",
DATUM["OSNI_1952",
SPHEROID["Airy 1830",6377563.396,299.3249646,
AUTHORITY["EPSG","7001"]],
TOWGS84[482.5,-130.6,564.6,-1.042,-0.214,-0.631,8.15],
AUTHORITY["EPSG","6188"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4188"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",53.5],
PARAMETER["central_meridian",-8],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",200000],
PARAMETER["false_northing",250000],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AXIS["Easting",EAST],
AXIS["Northing",NORTH],
AUTHORITY["EPSG","29901"]],
VERT_CS["EGM96 height",
VERT_DATUM["EGM96 geoid",2005,
EXTENSION["PROJ4_GRIDS","us_nga_egm96_15.tif"],
AUTHORITY["EPSG","5171"]],
UNIT["metre",1,
AXIS["Gravity-related height",UP],
AUTHORITY["EPSG","5773"]]]
When I remove the lines EXTENSION or TOWGS84 (that are the only difference)
from the WKT string, I get 1, 2 or 3 (depending on the combination of
deletion),
Doing more tests, I have the same behaviour with EPSG:25836+5773
Environment: Ubuntu 18.04. Compiled GDAL 3.2.0 and PROJ 7.2.0
Is this a know bug? Maybe fixed in PROJ 8.0.0? (I had not time to test it
there yet)
I do not like TOWGS84 either, but still many people is using it, and
provides WKT including it.
Thanks,
Javier.
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210426/0aac04c1/attachment.html>
