[gdal-dev] Test Data
Andrew Bell andrew.bell.ia at gmail.com
Mon Apr 26 14:51:37 PDT 2021
On Mon, Apr 26, 2021 at 10:44 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> DGN writing indeeds need GDAL_DATA to be set and point to the directory
> that contains seed_2d.dgn
Is it the case that GDAL_DATA is relative to the directory containing the
test rather than the test driver directory (autotest)? Changing a relative
path to an absolute one allowed the seed file to be found. This seemed
strange because the provided pytest.ini contains a relative path. Is there
some other variable that sets the base path to be used?
Thanks,
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210426/5e7bdb65/attachment.html>
